Specialized Warranty Expired - battery failure, what are my options?
Thank you vety much for the fast reply! Do you mean this fuse?
The big one is a Mosfet, here’s what you need to check. Be careful not to do any shorts in the process as you can easily destroy the bms by making a short by mistake, when taking measurements. Remember it’s a powered circuit you are working on!
And without proper equipment and skills it’s not easy to replace the said parts without damage.
Can anybody explain how to disconnect the BMS safely and reconnect to the new cells? What's the procedure?In what order do I disconnect it?
Rokus
Yes, I could do that (I think I already pointed out in one of my previous posting on this forum), but from your description, yours is most likely locked. Also, pack you're having is using LG MH1 cells which are crap, especially after a few years. I would never use LG in any of my builds and if you plan on replacing the cells, I suggest not using LG (MH1, MJ1, MG1). A better replacement would be Samsung 35E and you'll get 504Wh instead of 460Wh. Molicel M35A is also a very good cell but more expensive than Samsung.
Perfect! Thanks for the answers! Gonna order some good cells for this puppy! And probably send the BMS to you! Can I test first if the BMS starts working again once hooked up to new cells? Or do you say don't bother it will not work?
thanks!
thanks!
You can try it, of course. Just bridge those 2 points before removing the BMS from the pack. And remove the bridge once it's installed (all connections to the pack).
It was probably locked anyway, you said that input and output are both dead, cells are out of balance and bike doesn't turn on.
Mine is different, bike turns on but won't drive (probably voltage is too low) and there's voltage on discharge connector. Just don't have time to open and start working on it. And will have to wait for parts if needed, only locally available mosfet is IRF5210 (not even the s/to-263 version).
Many thanks for the geat support! The SFC fuse really is defective, but it was a bit tricky because it apparently still allows a leakage current and shows a resistance of 69 ohms. The mosfet's all seem to be intact. I’ll try to replace the fuse without removing the bms board from the battery pack. This week Lidl has a good DIY soldering kit on special offer :cool:
A SFC fuse has 3 terminals (usually). There is fuse itself, and the 3rd terminal is the heater (which has 10-80ohm depending on the fuse type). Guess what you measured is the heater resistance. It would be tricky to remove the fuse from the board without removing the BMS board. I'm not saying it's not doable, just that it needs some experience and some tools. In any case, you can also replace with a standard slow blow 15A fuse that you can solder over burned SFC. Also check the charging Mosfet for shorts (the big one near SFC).
