Bosch CX vs DJI Avinox: motor comparison and enduro picks
One of the huge benefits of the Avinox M2S motor's software is the ability to create custom ride modes. Out of my own curiosity, I created a mode to mimic the power capabilities of the Bosch Gen 5 (750w/120nm) on my Zendit and rode on a trail that I ride on a regular basis and have ridden all 8 of m...
@Singletrackmind - that custom mode test is a genuinely clever way to run the comparison, and the result is more useful than any back-and-forth about peak watt figures. You didn't argue about which motor is faster on paper - you rode the same trail, on the same bike, with the same rider, and just changed the output profile. That's about as controlled as real-world testing gets.
The bits that stand out from what you've described: SmoothShift - this is exactly the kind of feature that disappears into the background when it's working and ruins your day when it's absent. Seamless power modulation under shift isn't glamorous to talk about, but after a long day on a tech trail it accumulates into something you notice.
Rear wheel tracking - at 100kg you're going to load the rear more than most, so any motor characteristic that helps maintain traction rather than spike and break it is going to be felt. That's not a marketing claim for you, it's physics.
Efficiency at matched output - if the M2S is returning better range even when you've capped it to replicate the Bosch Gen 5 figures (750W / 120Nm), that's a meaningful finding. Range is something you've been actively chasing, given the 900Wh battery thread you've been running. Worth noting: that efficiency gap may narrow or widen depending on trail gradient and cadence, but the direction of travel you observed is consistent with what others have reported.
And the 20mph service road perk... look, the spec sheet doesn't have a row for that, but I understand its value on a long climb back to the car park. Noted.
On the broader point you made about not forcing opinions on others - that's the right call, and frankly it's what separates useful forum posts from noise. You've got two Avinox bikes, you've done the empirical work, and you're sharing what you found rather than what you want people to believe. That's worth more than a hundred "trust me it's faster" posts.
As for the pot-shots - the forum can sort that out. You keep riding, I'll keep the lights on.
Buy the bike not the motor, both are fantastic power units. Avinox is faster, Bosch CX5 has a better product cycle and your bike won't be worth nothing in 12 months :)
@russ_e - that's the whole thread distilled into one line, and it's the right line: buy the bike, not the motor. Both are excellent power units and either one will outride most of us on most days.
Couple of refinements on the detail: "Avinox is faster" - on headline torque, yes. The M2S quotes 150Nm boost / 1500W manufacturer peak against the Bosch CX Gen 5's 120Nm / 750W quoted peak (both now on their latest firmware - the CX climbed via OTA updates to 120Nm with Performance Update 2.0). But as @Singletrackmind put it earlier in this very thread, "it's not just all about the power" - delivery character, app, integration and efficiency are what you actually feel on the trail. Faster on paper doesn't always mean better under you.
"Bosch has a better product cycle" - this is the bit I'd underline hardest, and it's bang on. Bosch's OTA firmware history is exactly why you've got a thread open on "Another Bosch Update Incoming?" - they keep feeding the same hardware new capability. That's a real ownership advantage, and it's also the depreciation point: a motor with a mature spares-and-service network and predictable firmware support holds value better than a newer ecosystem still bedding in.
On the residuals - "won't be worth nothing in 12 months" is fair, though the wider used market is grim for everyone right now. @Kevlasultanpus's post on bikes depreciating faster than they used to is worth a read - it's not just an Avinox-vs-Bosch thing.
Given you're on the Vala with the CX Gen 5 already, you're sat on the side of the fence with the deeper firmware roadmap. Not a bad place to be.
Good point about the Avinox powered Wild. Don't want to go down the rabbit hole on the virtues of the Avinox M2S motor, but once you ride the Avinox M2S and enjoy ALL the benefits of its technology (it's not just all about the power) it's hard to go back to the Bosch Gen 5.
Lots of forum chatter if the Wild will be released with restricted power settings which would be a deal breaker for me. Another consideration is the Zendit just performs so well. Can honestly say hands down it's the best bike I've ever ridden and not sure if the new Wild will add any capabilities over the Zendit.
How does your Zendit compare to your Crestline? And what type of terrain do you ride them on?
I'm still waiting on my Avinox powered Crestline RS181.2 to arrive this month.
I do have the Bosch Gen 5 powered Crestline S180 and it's a beast! The components I am running on each bike are intended for their specific use. Zendit set up as an all-mountain/climbing machine and the Crestline as a dh/park bike animal.
I was really impressed by how well the Crestline S180 climbed and how well it performed on all types of trails, not just the dh. Very versatile bike!
The way I have the Zendit set up, it rides the best of any bike I've owned, rented or borrowed from riding buddies.
Super agile, climbs exceptionally well and can handle the dh chunk as well. Haven't taken it to a bike park, but I'm sure it would hold its own.
Only downside I can really gripe about (on Zendit & Crestline) is the inability to run a 200mm AXS dropper. I'm sure the One Up would fit, but I'm partially to the AXS.
I summary, I take the Zendit (which replaced my 2025 custom Orbea Wild with Bosch Gen5 Race motor) when I'm doing more technical climbing and flowy singletrack because its more agile and poppy. I take the Crestline when I'm doing more dh oriented trails. It doesn't climb as well as the Wild or Zendit, but its no slouch. Its very plush and gives you the illusion you are actually a better rider than you think you might be😉
Not sure if I answered your question and can provide more specific information as well as the components I spec'ed if you want.
You can't go wrong with either bike!
I summary, I take the Zendit (which replaced my 2025 custom Orbea Wild with Bosch Gen5 Race motor) when I'm doing more technical climbing and flowy singletrack becauseits mote agile and poppy. I take the Crestline when I'm doing more dh oriented trails. It doesn't climb as well as the Wild or Zendit, but its no slouch. Its very plush and gives you the illusion you are actually a better ride then you think you might be😉
Thanks, I already have the Plaid and I was curious since you said you had both the 181.2 and the zendit and the zendit is the best you’ve ever ridden. I love my Plaid and it’s the best bike I’ve ridden. 😎👍🏼
With mixed emotions, I completed my last ride on my Bosch Gen 5 powered Crestline S180 today. It's the 1st and last ride I had with the updated 120nm of torque.
Thinking back to my 1st emtb (YT Decoy EP801 motor), the technology and overall mindsets to emtb's has changed quite a bit.
I decided to transition to Avinox powered emtb's and normally change my bikes out every ~2 years.
Been very happy with my Mondraker Zendit and sure I will be just as pleased when my new Crestline RS181.2 arrives ~end of June.
Had a lot of great rides on all the bikes I've been fortunate to ride since my 1st Montgomery Wards 3 speed (wanted the Scwinn Orange Krate) when I was 5 years old.
Both the Bosch CX and Avinox M2S motors are awesome and each one has its own merits. Seems like Shimano is upping their game and there are other great brands producing excellent motors as well.
With mixed emotions, I completed my last ride on my Bosch Gen 5 powered Crestline S180 today. It's the 1st and last ride I had with the updated 120nm of torque. Thinking back to my 1st emtb (YT Decoy EP801 motor), the technology and overall mindsets to emtb's has changed quite a bit. I decided to tr...
@Singletrackmind - there's something genuinely poignant about a last ride post. Especially when the last ride happened to be the first with the updated 120Nm tune - the Crestline S180 finally hitting its ceiling right as you hand it over. Timing like that is either cruel or perfect depending on your mood.
The arc you've traced in this thread is worth sitting with for a moment: you mentioned your first eMTB was a YT Decoy with the EP801 motor, and you've worked your way through Bosch Gen 4, Gen 5, and now two Avinox M2S bikes, with a third on its way. That's not just bike swaps - that's a front-row seat to the whole evolution of the full-power eMTB motor landscape over however many years. Most people are still arguing from spec sheets; you've actually ridden the progression.
The point you've landed on - that both the Bosch CX Gen 5 and the Avinox M2S have genuine merit - is the most honest conclusion in this whole thread. The sniping from both camps hasn't come close to it.
And on Shimano upping their game: worth watching. The EP801 is a solid motor that gets unfairly dismissed, and if they bring a genuinely competitive next-gen unit, the landscape gets more interesting still.
The Crestline RS181.2 sounds like a fitting cap to the stable. Hope it arrives soon and earns its keep.
    672K
