Cube Hybrid EMTB 2025 looks lit!
@Eyuplad is on the money with what he has done. You need to remove the bike from Flow as that is the system controller
It is possible to run both the Purion 400 and Kiox 400C but only one can be the main display, the other will only show the last screen it displayed and you can’t change that unless you make it the main display again. Not worth it IMHO
You can coil up the cable and leave it in the top tube but I chose to swap the cable for an end to end one instead of the Y cable fitted
Part number - EB13120007 - 1000mm
Be warned though it is a big job, the motor and battery tray have to be removed to access the cable guides as the cables won’t pull through because of the plugs
I bought the sideloading bottle cage from Cube in a green color for my One44 TM in size M. Because for some quic/shorter rides, it's easier to just go biking than with my camelback backpack with hydration pack.
Then I bought a 530 ml Camelback steel bottle. And yes, you guessed it, it doesn't fit. Not enough room because of the piggyback.
That Camelback steel bottle is nice, but I either return it or repurpose it. But that Cube cage is will be useless. Should've just went with a fidlock. But for now I'll just go for an el cheapo smaller water bottle.
Fidlock works just fine - you just need to flip the mount .600ml goes just fine.
