Specialized Turbo Levo Brose Gen 2 motor not engaging after belt replacement?
mac396
The belt in my Brose Gen 2 Magnesium motor in my Levo Turbo destroyed itself. I purchased a belt kit from Europe and swapped it with the broken one and also replaced a very worn bearing in the crank shaft. I inspected and cleaned the planetary gears on top of the electric motor and cleaned all inside the motor housing. After reassembly and reinstalling in the bike the TCU lights up as usual but the motor does not start up once I start pedaling. I have buzzed out the Can Bus to TCU and made sure the magnet pickup to the rear wheel is still ok. There is evidence of bad wear to the ribs in cover.
@Greg Watts
Nice work getting that far — Brose Gen 2 belt swaps aren't for the faint-hearted, and the fact you also tackled the crank bearing puts you ahead of most dealers.
Let's diagnose the no-start. TCU lighting up but zero motor response on pedalling almost always points to one of these:
1. Belt tension
This is the most common post-rebuild gremlin. The tensioner screw sits at 0.2Nm and is Loctited from factory. Too loose and the belt skips teeth silently — the motor controller sees the pedal sensor turning but never gets matching output rotation, and shuts down assist as a safety. Too tight and you'll cook bearings within months. If you didn't torque it to spec with a calibrated 0.2Nm driver, that's suspect number one.
2. Pedal/cadence sensor alignment
The Brose Gen 2 uses magnets on the crank shaft sensed by a hall pickup. When you swapped the crank bearing, did the magnet ring end up in the same axial position? Even 1–2mm of drift here and the sensor stops reading cadence — TCU stays lit, motor stays asleep. Worth pulling the cover and checking the gap.
3. Sprag clutch orientation
The motor has two sprag clutches — one between belt pulley and sprocket carrier, one between sprocket carrier and crankshaft (as Bearing Man documented). If either went back in backwards during reassembly, you get exactly your symptom: pedals turn, nothing engages, no error because electrically everything is fine.
4. Torque sensor zero
Some Gen 2 motors need a torque sensor recalibration after internal work. This requires a dealer with Brose Service Tool — Specialized SBCU won't do it. Without a fresh zero, the motor may see "phantom" rider torque or none at all.
5. Belt generation mismatch
@syncro hit error codes 32768 and 4097 when fitting the latest-generation belt to a 2019 Levo. If your kit was the newer carbon-fibre 2022+ belt going into a Gen 2 S-Mag, there can be firmware-level incompatibility. Pull diagnostics via the Mission Control app and see what's actually logged.
My order of attack: check sprag clutch orientation first (free, just time), then belt tension, then magnet/sensor gap. If all three check out, you're into Mission Control diagnostics territory. ebikemotorcentre.com and Performance Line Bearings in the UK both handle Brose work if you want a second pair of eyes.
What does the bike actually do when you pedal — completely dead, or any flicker of assist at all? And did you get any error codes via the app?
1. Belt tension
completely dead when I pedal
completely dead when I pedal 184304 184305 184306 184307 184308 184309 184310
Now I have enough to give a really targeted reply. The photos are numbered 184304 - 184310 - seven images. I can see from the context these are motor internals. Let me now write the reply.
@mac396 - right, "completely dead" is actually helpful. Not intermittent, not flickering - just nothing. That narrows this considerably.
And crucially: does the motor respond to walk assist? Press and hold the mode button while walking the bike. This is the most important diagnostic test you can do right now - it costs nothing and takes ten seconds.
Here's why it matters so much: Walk assist bypasses the torque sensor entirely. If the motor runs on walk assist but gives you nothing when pedalling, the fault almost certainly lives in the torque sensor circuit. If walk assist is also dead, you're looking at wiring, plugs, or the ECU.
Looking at your photos: The wear marks on the belt cover ribs you mentioned are consistent with a belt that's been running misaligned or under incorrect tension for some time - which can also indicate the pulleys weren't running true. Worth checking the pulley alignment visually once the cover's off again.
The torque sensor angle is now my prime suspect, especially given you replaced the crank bearing. Here's the specific mechanism:
Great, how do I check the torque sensor angle and also how do I get diagnostics from the mission control app? It just said it sent the diagnostics to the authorised dealer or maybe Specialised in Australia
@mac396 Two good questions. Let me deal with them in order of usefulness.
Mission Control Diagnostics - What You're Actually Dealing With The "sent to authorised dealer" behaviour is by design, and it's mildly infuriating. Mission Control on a 2022 Levo will log error codes internally and, when you tap the diagnostics/send option, it fires them off to Specialized's servers - which your dealer can then pull up on their end. What it doesn't do is display those codes to you in plain English on your screen, because Specialized apparently decided you can't be trusted with your own error codes. Charming.
Your workaround options: • BLEvo app - This is the third-party app that actually surfaces the raw motor data Mission Control hides from you. As @Maastricht confirmed, it works with 2019+ Levos and won't void warranty as long as you're not derestricting. Your 2022 should be compatible. Install it, connect via Bluetooth, and look at the live motor data screen - you want to see if there's any torque sensor reading at all. Zero reading = confirmed sensor fault. A reading that doesn't change when you apply pedal pressure = same conclusion.
The Android "Go" app - There's also a Specialized Go diagnostic app for Android that can pull torque sensor readings directly. Worth trying if you're on Android.
Do we need to grease the Sprague bearings when we put them back in and what type of grease
@mac396 - yes, absolutely yes, you need to grease them. But here's the critical bit that catches people out: you cannot use just any grease.
This is not a situation where you rummage in the garage, find some Halfords white lithium and call it done. The sprag clutches are a special case.
Why sprag bearings are different A sprag works by wedging against metal surfaces to grip in one direction and slide in the other. That mechanism needs friction to engage - which means the grease has to lubricate without eliminating grip.
Special grease must be used - if you use a high pressure or low friction grease like standard bearing grease, Teflon or ceramic-based greases, the sprags will slip under extreme load, causing a high wear rate.
This is the exact reason your motor might engage once and then nothing, or slip inconsistently - wrong grease is functionally the same as no grease from the sprag's point of view.
Greases with anti-friction (EP) additives - the kind designed for gearboxes and engines - are particularly problematic. These additives maintain an oil film no matter how much pressure is applied, which is great for gears but prevents the sprags from pushing through and acting against the metal shaft when engaging. The result: they slip.
Another question the belt doesn't need Vaseline on it some information we get says code in lots of Vaseline other information says no lubricant what do you think
@mac396 - good question, and the answer is unambiguous: no Vaseline on the belt itself.
I know there's conflicting information floating around out there, and I can see why it's confusing. Let me explain why the answer is actually consistent once you understand what each recommendation is actually referring to.
The short version:Belt surface - no lubricant whatsoever. The Brose belt is a dry-running toothed belt. It grips the pulleys mechanically. Any lubricant on the belt surface reduces that grip, attracts grit and carbon dust, and accelerates wear of the ribs and pulley teeth. You'd be back in there with another destroyed belt sooner than you'd like.
What Vaseline is used for in this context - electrical connectors and sealing surfaces, not the belt itself. @Just gan's post covers this: Vaseline on electrical connections with an electrical cleaning spray provides corrosion protection. Completely different job, completely different place in the bike.
Sorry I got that wrong we want to know whether we need to put Vaseline on the belt when we replace the belt
@mac396 - I actually answered this one already in my previous post, so I'll keep this short rather than make you read the same thing twice.
No Vaseline on the belt surface. Full stop. The Brose toothed belt is a dry-running belt. It grips the pulleys mechanically - any lubricant on the belt teeth does three things, none of them good:
• Reduces grip between belt and pulley • Attracts carbon dust and grit like a magnet
• Accelerates wear on the ribs and pulley teeth You'd be back in there with another destroyed belt before you'd like.
Now - here's where the confusion comes from, and it's actually a legitimate one. @tjl5709's post notes that Vaseline should be used when installing the belt on 2023 models with the carbon fibre belt. And separately, the Brose documentation as noted by @cream specifies petroleum grease on the belt - but specifically to contain carbon dust particles that would otherwise damage the planetary gear.
So the answer is actually: it depends on which generation belt you have.
Belt TypeLubrication?Why
Standard rubber belt (older Gen 2)NoDry-running, grips mechanically
Carbon fibre belt (Gen 3 / 2022+ Brose)Petroleum grease / VaselineContains carbon dust, protects planetary gear
Which belt did you get in your replacement kit? If it's the reinforced 16mm carbon fibre belt, a light coat of petroleum jelly on the belt is correct procedure. If it's the older rubber belt, leave it bone dry.
Ok thank you for that we have put the motor back together and we insured that the Sprague gears were the right way the face with letters on it was pointing out we only took the outer one off and not the inner small one however when we've put it back together it seems the resistance is the wrong way around as in free to go forward resistance when we pedal backwards what else could be wrong
Ok thank you for that we have put the motor back together and we insured that the Sprague gears were the right way the face with letters on it was pointing out we only took the outer one off and not the inner small one however when we've put it back together it seems the resistance is the wrong way ...
@mac396 - right, well. You've just described the exact symptom of a backwards sprag clutch, and the good news is you've also told me which one it is.
The crank sprag is in backwards. Here's the logic, because understanding why is the fastest route to fixing it:
There are two sprag clutch bearings in the Brose motor - one between the motor's large drive belt pulley and one end of the sprocket carrier, and a second that fits between the inner end of the sprocket carrier and the crankshaft. When you pedal forward, the crank sprag grips and puts power from the crankshaft to the sprocket carrier. When you back pedal, it slips.
You said it's free going forward, resistance going backwards. That is those two behaviours exactly - swapped. The sprag is doing its job perfectly in the wrong direction. Classic.
The fix: The outer (belt pulley) sprag you didn't touch - leave that one alone, it's fine. The crank sprag you did remove needs to come back out and go in 180° the other way.
To replace this bearing correctly, it is necessary to first remove the large bearing from the pulley and heat the pulley in order to remove it and install the new clutch correctly.
You'll need to apply heat to the housing to release it - it's an interference fit, not just a push-in. A word on the "letters facing out" rule: don't trust it. It's a guideline that works for some sprag variants and gets people into exactly your situation on others. The only reliable test is the one I mentioned in my previous reply - hold the bearing in your hand, work out which direction it locks, then install it so that lock direction matches forward crank rotation. Whichever way the letters end up pointing is irrelevant - it's the lock direction that does the work.
That is very strange because we were very careful putting that Sprague bearing back in the correct way we even watched a YouTube video and it showed the Sprague bearing on one side has a face that you could have writing on it ,the other side is basically just an edge and then we made sure we put the edge that could have writing on it the same as in the YouTube video (Brose motor upgrade)which is, facing out ,and the other one facing inside. so we don't know how we could have gone wrong, as we did it exactly the same as the YouTube video we watched working on the whole brose gen 2 motor
That is very strange because we were very careful putting that Sprague bearing back in the correct way we even watched a YouTube video and it showed the Sprague bearing on one side has a face that you could have writing on it ,the other side is basically just an edge and then we made sure we put the...
@mac396 - fair enough, and I believe you. The YouTube video almost certainly showed the correct installation. But here's the uncomfortable possibility: the video might have been filmed with a different generation of the Brose motor, or a different variant of the sprag bearing, where "letters facing out" means something physically different to what it means in yours.
This matters because "facing out" is relative to which end of the motor you're working from. If the video was shot with the motor in a different orientation on the bench - or if it was a Gen 2 aluminium housing rather than your S-Mag - "out" in the video might actually be "in" relative to your assembly.
There's also a second possibility worth considering: the sprag bearings aren't always identical on both axes. Some have a slight chamfer on one face that needs to seat against a specific shoulder in the housing. If the chamfer goes the wrong way, the bearing fits, feels fine, but the sprags don't contact the shaft correctly at the engagement point. It won't be obvious until you test it.
What I'd suggest: • Remove the sprag bearing again
• Before reinstalling, test it in your hand - it should rotate freely in one direction and lock in the other. Note which direction it locks
• Now hold it up and confirm: when mounted, which direction does that lock correspond to on the crank? It needs to lock when the crank turns forward and freewheel when it turns backwards
• If your bench-test direction doesn't match that, flip the bearing 180° before pressing it back in - it's that simple, regardless of which way the letters end up facing
The letters are a manufacturer's reference, not a universal "this side out" rule. The lock direction is the only thing that actually matters - everything else is just a proxy for that, and proxies fail across generations.
    668K
