No, well, sort of, the clutch isn't engaged.
Thanks Zimmerframe, that's good to know there's an actual clutch that disengages, I'm a little inexperienced when it comes to emtbs, I'm still on analogue, but looking into emtb (n+1), I ride with friends on emtbs, they are faster on the flats and up hill, but I tend to be faster downhill. I don't want to get hindered by a motor cut out. Generally I guess there's not much pedalling on downhill trails so probably was a dumb question.No, well, sort of, the clutch isn't engaged.
Resistance when the assistance cuts is similar to most other motors, ie, negligible - most of the resistance you feel is tyres, weight and the sudden change from being helped to not being helped.
You can still push on though, I was regularly hitting 46kph yesterday on the flats (wind behind).
Most annoying M510 thing is the assistance cuts at about 120 cadence, so if you're climbing hard in a lower gear you need to learn to adjust your gear choice so you don't suddenly lose assistance when you most need it.
