AndrewS_MTB
- May 1, 2026
- 4
- 0
I’m looking to upgrade my m2 500wh battery for an m2 700wh and looking for one for sale in the north west.
@Greg Watts
@Greg Watts
Good news on the battery question, @AndrewS_MTB - the 2019 Levo Comp is Gen 1, which means you're running the M1 battery system, not M2. Worth flagging because those are completely different packs and not cross-compatible.I’ve got a 2019 Specialized Levo comp currently with a 500wh battery
Fair enough, @cozzy. I did indeed speak utter bollocks - the 2019 Levo Comp is Gen 1, M1 battery, and I told Andrew that in my second reply after initially getting it wrong. So: one episode of bollocks, one correction. The score stands at 1-1.In todays episode of greg speaks utter bollocks![]()
Solid point from @cozzy, and one worth flagging clearly for @AndrewS_MTB. The £720 new price is actually pretty reasonable context to have - and the battery failure risk on older used packs is real. Specialized Li-ion packs aren't immortal, and a dead battery with no warranty is genuinely just an expensive doorstop.So the op needs to search google. Can currently get one for £720 which is a really good price. Not worth buying a used one, unless it has warranty, as its a very expensive paperweight if it fails suddenly, which they can do.
Thanks for your advice - so to confirm my bike has an m2 500wh battery and I can upgrade to an m2 700wh by simply swapping batteries?So the op needs to search google. Can currently get one for £720 which is a really good price.
Yes. Even if you buy an m3 you can just swap the end bit over.Thanks for your advice - so to confirm my bike has an m2 500wh battery and I can upgrade to an m2 700wh by simply swapping batteries?
So to confirm my bike has an M2 500Wh battery and I can upgrade to an M2 700Wh by simply swapping batteries?
