Wojtek
- Mar 13, 2026
- 102
- 89
No options with 932wh battery?
Who says there's a 932wh battery?No options with 932wh battery?
Rumours.Who says there's a 932wh battery?
Would be a bummer since the current 800Wh is quite a bit meager.Who says there's a 932wh battery?
Same price as last year's 800wh model but we get 700wh. Hows it a good deal?Would be a bummer since the current 800Wh is quite a bit meager.
Big difference in downtube size there.Left, 800Wh entry model (two specs options)
Right, 700Wh top model (two specs options)
Yeah, I missed it before it was taken down.Why was the side by side picture showing the downtube thicknesses removed?
Looks like there is no spider and the chainring is now directly attached to the motor?That chainring size is perfect for ridingderestricted"NZ mode" or "class 3"! They know what the people want![]()
If that's real! You would expect the one on the left to have a bigger battery than 800Wh.
Why? Looks about par for the course for a downtube door (i.e. not a slide out) battery in 2026If that's real! You would expect the one on the left to have a bigger battery than 800Wh.
Based on leaks, I have no info:Yeah, I missed it before it was taken down.On page 1 of this thread there were low-res pics of both PX and PR models. The white PX model looked like it had a very thin downtube, but I think that was just because of the sort of hazy line between the tube and the background, as the black PX model downtube looked nearly as thick as the PR models. Certainly not the 2x difference I see mentioned above. I saw some other genuine pics of them and it looked like the PR has a more square cross section downtube (vs. rounded on the PX), and a full length black protector on the underside (vs. a short protector down by the BB on the PX), so depending on how the light hits it, it may appear differently.
Back on page 1, someone also said the PR is supposed to weigh 2kg more than the PX. A downtube cutout typically only adds about 0.5kg. Does anyone more familar with battery weights know roughly how much more an 800wh battery would weigh than the 700? Does an extra 100wh likely account for the full additional 1.5kg, or does that weight increase indicate there is still hope for the 900wh+ battery?
If there is no bigger battery, and no range extender, then that removable battery setup will have to be pretty awesome to compensate.
On the plus side, I do like the adjustable headset cups and chainstay flip chips. I'd also ideally like to see a flip chip at the swing link but , since they don't seem to have incorporated one, I guess offset shock bushings are always a DIY option to tweak the ride height a bit more.
Yep. The whole point of removeable battery for me personally was being able to charge in the apartment.Based on leaks, I have no info:
600Wh = 2.9kg while the 800Wh battery weighs 3.7kg, assuming 700Wh gains no weight = 800g for battery
Motor: entry level M2 vs high level M2s = 300g
Battery latch mechanism, at least 500g
so there is the 1.6kg, looking at the size of the downtube it must be a few hundred grams more.
The lack of 900Wh batteries is a huge bummer now that we know they have the cells to do it, unless they really knock it out of the park with a 1kg 300Wh extender. My probability of getting an avinox powered bike next month has gone down from 90% to 40%![]()
Come on, show usThis battery will be only avaliable in top spec Amflow bikes so for sure it has something special no other brand will have.
Wanna see a real picture of the new downtube with the 700Wh inside?
The image has been in this forum some hours ago and then I delete it.Come on, show us
The photo in post #77, with the 2 white bikes leaning against the wall, is the new PX (integrated battery) and PR (removable battery). Without measuring it is tough to tell, but it seems like, when compared to the 1st gen Amflow bikes, the PX may have a slightly smaller downtube, and the PR looks like it has a considerably bigger downtube. The PX seems to be 700wh, and the PR I think is 800wh, but I don't think that the PR battery capacity is 100% confirmed yet.Just catching up here, so is this a super slim 700w battery? Or is just the angle? Downtube looks a lot smaller than other DJI models.
Wow, thanks for bringing our attention to that! There was someone here on EMTB Forums within the past few weeks who claimed an Avinox Range Extender would be released soon, but he offered no more details, and I have seen no other mentions of it until now, so I didn't want to get my hopes up. This further mention, complete with a Wh spec, is very encouraging.Meanwhile
Over on FB ...
Ref. PX models
Spanish contributor is saying there will be a 600Wh Extender !
(Note: He is calling them PX and PX Carbon = PX Carbon and PX Carbon Pro)
www.facebook.com
Magura Sensor Rotor ? Front rotor ? Is that such a thing
