Too bad their "40 second" installation isn't warrantied. LOLGood news, Tannus have thus far replaced four ..........
"We put them first time on our ebikes almost 5 years ago and... I've forgot what's flat tyre since then. I've actually forgot about it as well until I needed to change my tyres as they wear out!
When I've got my new bike this spring - I've put them back - whole season, 1500 km done and no single puncture."
Do you deflate after every ride??
Why?Since getting the new bike, I've been riding much more aggressively. And have punctured the rear tube in 3 of the last 6 rides. Most have been impact pinches. Desperately trying not to use tubeless and sealant. I installed the Tannus insert on my rear tyre today.
Because it's messy when I do puncture or peel a bead off, and need to throw in a tube. It's also messy when I swap tyres at home to do my gravel rides. I run much lower rolling resistance tyres when doing these rides as we ride much further, and I need as much range as possible. I also run the TPU tubes on these rides, so it's actually lighter than running sealant. I don't run inserts on these rides as I have never punctured.Why?
Been using them for years, no punctures, they do squash over time and need to be replaced even at 25psi. I don't deflate after every ride any more - too much of a faff! They don't seem to recover when deflated anyway.The joy of autumn...hedge cutting. I just dug three blackthorn spikes out of my tyres and wondered if there was a better way.
Anyone used tannus inserts. They look good but there's got to be down side.
Nigel
I clean the bike and drivetrain after every ride. So deflating the tyres is part of this process. I then always check tyre pressure before a ride, with a miniature Lipo inflater, and inflate back to 22psi. It just takes 30 seconds. It does seem to make the inserts last much longer.I don't deflate after every ride any more - too much of a faff!
