Singletrackmind
Where did you purchase these from?Just got the first new and perhaps the most critical of parts going for the upcoming build, the top cap(s)!!
Bit of background first.Can I get @Greg Watts to summarize BikingBad's experience with different chainstay lengths on his Crestie or does that not work anymore?
I’ve been riding about 15 years, nowhere near the extensive experience some others here have. On a good day, i‘m an “intermediate” rider but I do ride everything.
Bike (RH3, MX, 445CS) never felt right for me from the start. Unlike all other MTBs I currently have and had over the years (~7), I felt more like a passenger riding it, instead of the driver. Changing to 435CS helped a bit but not nearly enough as what’s happening at the front of the bike was the culprit.
Long story short, two things addressed the issue. First, new Fox 38 Factory fork was over greased from the factory (known issue). Removing the excess grease significantly improved low speed sensitivity. Second, changing out the 800Wh battery to 600Wh removed 2 lbs from front/top of bike, improving handling, agility, easier to lift front.
With the problem fixed, I reinstalled the 445CS to improve stability on fast, steep, chunky, techy DH trails, which it did.
If 800Wh battery was my only option I would’ve kept 435CS.
Hope this was helpful.
Sounds like it. Yes, Fox 38 Factory Grip X2.Does your 38 have the grip x2? I have the newer one and its much better than the previous damper, in my opinion anyway. Funny, I had to send mine in for warranty because of cavitation, twice lol. They replaced the air spring this last time, but I swear it just had too much grease in it.
I need that Red one. lol. Where did you grab them? I haven’t seen them on the site.
If 800Wh battery was my only option I would install 435CS.
Explains why a Spectre with 600Wh battery was sent to Pinkbike for review.Thanks for that great explanation.
It would appear that the desired long narrow 800w battery, is actually quite the negative to bike handling, at least in your case.
Its a full power e-bike, i wouldn't care about overall weight. Especially with the fork and tires. The battery I get, but even then it still mounts in the same spot, so I'm not sure how much difference the bike will feel swapping from an 800wh to a 600wh.Looks like the line for the 600wh battery is forming already!
There was an option for the 600 when I picked up the bike, but I went for the 800 since I go for longer rides and dont like to be limited based on juice left. I would obviously love the lighter weight for better handling and more nimble riding characteristics but there is a trade off.
I am hearing the 600 is going to be available this year and I am planning to get one if I have enough in the reserves after getting an idea of how much juice I am using on my average rides.
On this note, anyone going for a 36 fork, 160mm, trail casing tire, "lightweight" build up?! This may be a good way to go if youre not always plowing through the roughest stuff..
Not knocking your decision or thought process though. I feel on a full fat e-bike you'd want the burliest stuff since its pumping out up to 1000w up hill so no suffer penalty.
I think of it like I need an 800Wh+ battery so it doesn't really matter to me how a bike with a 600Wh battery handles.Yeah, I wouldn’t want to limit my range to be able to go hard for a full ride. If I was going to the bike park with a lift, then the 600 would be fine. But that’s not going to work for me on all of my local rides. Proper suspension and cockpit setup will alleviate any handling issues with the big battery.
800Wh versions definitely sold out before 600Wh models. Yeah the 600Wh sold out nearly as fast but that’s likely more a testament to Crestline and Avinox than an indicator of small battery popularity. Obviously there’s a lot of knowledgeable people who are looking for a high quality Avinox powered bike instead of the low-end Amflow that people are breaking.All the 600wh options did sell out just as quick as the 800wh's, so there are those that will enjoy the lighter weight battery option for certain!
I definitely love all the tunability this frame has with the dropout options, reach adjust, and travel adjustments. Seems like it can be really honed in for the individual riders preferences. Not many bikes I know can run 160 to 200mm forks!
Anyone plan on running a 40 dual crown 180-200 fork with all that juice on tap?!
I have a 38 and a 40. I’ll start with the 38 and see how it goes. If they come out with a 200 link later, I’ll stick the 40 on for a 200/200 beast. I’ll keep the 38 on in the meantime just because it has a better turning radius and my local trails have a lot of tight switchbacks and a single crown is much easier in that scenario.All the 600wh options did sell out just as quick as the 800wh's, so there are those that will enjoy the lighter weight battery option for certain!
I bought the CL with an 800 battery, but definitely want to grab a 600. I ride at a few shuttle parks that also have trails to ride up if you dont want to shuttle. But yea, I feel like the bike will be more fun on jump lines with the 600. However, I did buy the 800 for a reason lol800Wh versions definitely sold out before 600Wh models. Yeah the 600Wh sold out nearly as fast but that’s likely more a testament to Crestline and Avinox than an indicator of small battery popularity. Obviously there’s a lot of knowledgeable people who are looking for a high quality Avinox powered bike instead of the low-end Amflow that people are breaking.
No there’s a separate bolt hole for 600 on bottom of down tube. It’s lower and you don’t have to remove the display from what I read. So yes it lowers center of gravity.Y’all realize that the battery regardless of size bolts in the top of the down tube right?
I don’t think a 600wh will “lower” the COG. It will move it slightly but you’re loosing weight on the bottom not the top.
Now I have ridden it yet, so grain of salt here, but I really don’t think a battery swap will feel all that different.
Yup. What matters more is the placement of the extra 2 lbs.A 600w bike is overall 4% lighter with 25% less range. That's the maths I did.
