Rail (750Wh) Rockshox Vivid on a Rail?
I've gone with a 500lb spring and will see how it rides
I'm 82kg and the bike is 25kg with a water bottle.
Photos to follow once the spring arrives
It's interesting how little shaft travel there is on these coil shocks.
Mine is a 60 but has about 5cm of shaft travel, before it hits the bottom spacer.
So - it's now fitted and looks amazing. Thanks for your help @Rail7Lou :)
I can't wait to ride it.
Rockshox Vivid Ultimate RC2T coil shock, 230x60, Rail size Large.
500lb spring, rider weight 83kg, and the sag is around 28%
Anyone tried that Rock shox coil on medium gen 2 alloy ?
Yes and the piggyback chamber hits the downtube at full stroke compression. Sadly the M size gen 2 frames don't have enough clearance but the larger sizes and later models with the 750Wh battery do. I think I also tried a Fox X2 and had the same issue. In the end I went for a DVO Jade X which has the piggyback oriented laterally. This and other shocks with the same chamber orientation works fine.
    668K
