Sounds promising. Would be useful to know what set up he used. I guess it's going to be a case of limited coil size optionsVitus advised that there is not, and there definitely is not if you keep the plastic shock guard in place - however Adam Brayton has fitted one to his recently, so think it is possible - I am looking to do the same.
I'll watch the video ?????Sounds promising. Would be useful to know what set up he used. I guess it's going to be a case of limited coil size options
Thanks Gary, I'll call the distributor tomorrowPersonally I still see fitting a coil as a downgrade for my riding on the E-Sommet.
But I love the set-up with the super Deluxe.
A coil shock for me would be less playful/progressive (less well suited to the leverage curve) and a fair bit heavier. But I can see fine well why others might disagree. Especially if maximum grip, and plowing through stuff DH are your main priorities.
Brayton's running an Ohlins so calling their distributor might make sense.
Yes that's the one. I don't unfortunately, the tech ran through specs but I didn't write them down. He did say there was less adjustment on this shock but still an amount at least equal to the others as they don't include the fully open/fully closed options that in real world conditions aren't used. (often) The shock off the shelf isn't 205 x 62.5 but the tech is adjusting one to be exactly that.Thanks that’s helpful - I think the other one my have been the Fast coil shock.
Do you know the spec of the shock?
I'm abroad with work but will post pics when I'm back Friday. 14.5 stone with full kitAnd how much do you weigh?
Yes. Had to remove the guardPictures please! Did you have to remove the shock guard?
Phew... thought it was all heading a bit 'readers wives' there for a second.I'm abroad with work but will post pics when I'm back Friday. 14.5 stone with full kit
That was my issue. The upgrades were subtle and I thought they needed to be far greater, hence the switch.I'm actually blown away after just two proper rides by how improved by the subtle changes to damping and airspring curve the Super Deluxe on my 2019 bike is in comparison to the 2018 version,
??Phew... thought it was all heading a bit 'readers wives' there for a second.
Luckily I've got red decals instead of amazing hope parts. It's more street ?Looks way nicer than Brayton's too without all those ugly red Hope parts stuck on everywhere![]()
How did you cover/remove them. I'm thinking of going bare... I need to clarify this don't I Gary ?. Frame back to metal with a clear coat over whatever decals I chooseI've actually stealthed out all the green and all my frame decals except the top tube ones now.
#StreetAF![]()
Just wear a hash leaf beannie. Yeah they dropped the ball a bit with the colour scheme but that's the only thing. Good work vitusStripping/painting the frame voids warranty on the entire bike (motor incvluded). I checked when I bought my 2018 and again 2 weeks ago. and a Warrantyless Ebike is not something I'd consider owning.
Mine is wrapped/taped with a mix of car vinyl black insulating tape and mastic 2228 tape.
not the most pro job but still looks better than that awful green and red.
WTF were they thinking there?
...But ran out of budget for the gold and hash leaf headbadge![]()
