Oh aye, they are all adding 10kgs onto themThe downhill racers are adding weights to their bikes around the bottom bracket area to make their race bikes work as good as their e-bikes.
That should tell you all you need to know.
Terribly, stay away.So how well do bikes this heavy tend to handle for downhill, climbing, tight banked turns, jumps and drops, etc?
Are they using forks with greater offset like DH bikes use?My take: many heavier/longer wheelbase eMTBs tend to have a bit of understeer. Also, the bike design can make a huge difference in how it feels coming off jumps/drops - bikes that are nose-heavy can be downright scary at first vs a regular MTB. I find that I run my bars about 20mm higher on the eMTB to help balance things out a bit.
Depends on the specific frame geometry - largely HTA and wheel size.Are they using forks with greater offset like DH bikes use?
If you raise the fork travel 10mm over OEM stock no it balances out but I have been told few people can really tell the difference regardless.Both of my E-bikes (My wife's Trance X with a 160 fork and my Ari Nebo) have forks with 44mm offset. Both have 65 degree HTA's. For my application, I doubt I'd notice the difference with an offset of 52mm.
I think you're right.The weight and and low CG of an eMTB mean they actually handle really well and rip downhill. The additional sprung weight also helps the suspension perform better. Between that and their weight they have loads of traction.
Regarding downhill the weight of an E bike is your friend.
How much is excessive, how much is too little, and how much is just right?...as long as its not excessively nose heavy.
irie said:How much is excessive, how much is too little, and how much is just right?
Are you saying that the excess weight assessment applies only when swapping between using a regular MTB and an eMTB with radically different weights?IYKYK. It's when the weight balance is radically different from a regular MTB and you go between them.
Do you mean the weight balance difference when, as you said above, swapping between two bikes?It’s not the weight though - it’s the weight balance.
YupDo you mean the weight balance difference when, as you said above, swapping between two bikes?
irie said:Do you mean the weight balance difference when, as you said above, swapping between two bikes?
Then that's due to your inability to deal with the inherent differences between the two bikes when moving from one to the other.
