eMTB handling?
wb3jma
So how well do bikes this heavy tend to handle for downhill, climbing, tight banked turns, jumps and drops, etc?
I don't know how to answer that. What would you say if someone asked you how a 35 pound bike handles downhill, climbing, tight banked turns, jumps, and drops. How does a 25 pound bike handle downhill, climbing, tight banked turns, jumps, and drops? What we really need to know is how do YOU handle downhill, climbing, tight banked turns, jumps, and drops?
Better than you’d expect, in general.
It varies a bit because some ride like 💩 (as do some regular bikes) and some ride amazingly. There’s roughly a 9kg weight difference between the lightest SL and a lardy full fat, so you might need to narrow it down to what you’re looking at.
Cornering well requires getting the bike leaned over to engage the cornering knobs on tires. E-bikes tend to have slightly higher CG's combined with more mass, so swinging that mass from one side to the other requires some minor technique adaptations. It's not difficult, just a little different.
Climbing, well, you have a motor! You no longer have to be too concerned about putting on grippy (and heavy) tires, and suspensions can be used that don't require as much climbing efficiency.
Descending just requires some adaptations in suspension, which manufacturers have done pretty well through shock tuning and such.
Jumps and drops aren't a big deal. Again, it's just a matter of degree and adapting technique a little bit. People ride 250+ pound motocross bikes. A 50 pound E-bike is not a huge jump up from a 35 pound DH bike, in comparison.
My take: many heavier/longer wheelbase eMTBs tend to have a bit of understeer. Also, the bike design can make a huge difference in how it feels coming off jumps/drops - bikes that are nose-heavy can be downright scary at first vs a regular MTB. I find that I run my bars about 20mm higher on the eMTB to help balance things out a bit.
We don’t tend to talk anymore about how e-bikes actually ride or handle here on EMTB, we’re only interested in how powerful they are… 🤭😉
Seriously though, you really need to ride anything you’re interested in.
Are they using forks with greater offset like DH bikes use?
Both of my E-bikes (My wife's Trance X with a 160 fork and my Ari Nebo) have forks with 44mm offset. Both have 65 degree HTA's. For my application, I doubt I'd notice the difference with an offset of 52mm.
If you raise the fork travel 10mm over OEM stock no it balances out but I have been told few people can really tell the difference regardless.
Funny you mention that. On my wife's Trance X, I did extend the fork from 150mm to 160mm. It was easy to do, but I didn't really notice a difference there either. But I think for my wife, the more upright the sitting position is, the better - for comfort and reduced back stress. She's 72 and this was the first season for her, exclusively riding an E-bike. So far, that geometry hasn't had any negatives.
I agree, though. In most cases, the differences are very subtle.
How much is excessive, how much is too little, and how much is just right?
IYKYK. It's when the weight balance is radically different from a regular MTB and you go between them. I almost killed myself on a big drop on my first eMTB (KTM Macina) because it was soooo nose heavy. Levo was bit better but still , Rise was good, and Amflow is good. Can be quite butt puckering when the front of the bike dives in off a jump!
Are you saying that the excess weight assessment applies only when swapping between using a regular MTB and an eMTB with radically different weights?
The heavier they are, the worse they handle compared to a 25-35 lbs MTB. You DO get used to it though but you will likely never get it to feel as nimble or pop off features as quickly and easily as a 30 lb MTB. I ride both...my fastest downhill times are on my Ibis Ripmo and the Specialized SJ EVO. I have to brake less on those and can fly over things easier and pump easier. The eMTB is MUCh more planted and grinds down and of course takes more effort to brake.
Then that's due to your inability to deal with the inherent differences between the two bikes when moving from one to the other.
No, it's due to my desire not to deal with a nose heavy bike if I can avoid it. Raising the bar height 20mm helps.
