Storing battery in the fridge?
“Effect of Temperature on Lithium-ion Batteries
All batteries experience a loss in performance at low temperatures. The ideal storage temperature for most batteries, including lithium-ion, is 59°F (15°C). Temperatures dipping down at or close to 32°F (0°C) cause a slow-down in the chemical reactions inside of the cell—resulting in a loss in capacity of the battery. When users put a battery under heavy load at cold temperatures it can cause a phenomenon known as cell reversal. This is a common cause of failure in cordless power tools. Users who need their lithium ion batteries to function in cold climates should be aware of these temperature effects on batteries. Store them in a safe, temperature-controlled space during the winter months.”
I dont think "someone mentioned . ." is a dependable source of information when there are multiple reliable sources for tech info, not least
READ THE MANUAL!
READ THE MANUAL!
Why bother with all that when AI can give the answer in an instant?:rolleyes:o_O:eek::eek:
Quote:-
Conclusion​
While storing lithium batteries in the fridge can reduce their self-discharge rate, it is crucial to manage the risks associated with condensation and temperature changes. Proper storage techniques can help maintain battery performance and safety.
Nothing like hedging your bets and if AI knows about it there must be a body of writings that suggest it is a good idea, when in fact most of us know it is not as is asking AI about anything.:ROFLMAO:
Actually, it's complicated...
It’s better not to take everything an online AI says as automatically correct. They often repeat misconceptions that circulate widely on the internet. Even manufacturers sometimes provide guidance that can be tricky to interpret properly if you are not an expert or at least familiar with physics and chemistry.
In conclusion there isn’t a simple yes-or-no answer: it depends on the type of battery, how long you need to store them for and many other details. And even then there are specific safety procedures that must be followed when storing them in a refrigerator or taking them out again to avoid damaging them.
Here is one of the more thorough sources I’ve found on the subject:
The reason why we do not need put batteries in freezer? | ELB Energy Group
Tips If You Put The Batteries In Freezer?​
1. Your fridge needs to be a dry environment (some older fridges can be damp), or the battery casing or terminals may rust causing toxic leaks that you really don’t want near your food.
2. Do not use a battery straight from the fridge, allow it to warm up gradually to room temperature (a few hours is needed for a unit to warm right through).
3. Don’t try to accelerate this warming process (say by putting it beside a sunny window), as this will cause the outer parts of the battery to become too hot and excessive heat accelerates self-discharge.
4. While the battery is warming up, keep it in a well ventilated area to avoid condensation which could cause shorts or rusting.
5. For everyday usage, don’t get too hung up on it. The benefits are very small unless you are talking about commercial storage to extend shelf life.
My personal opinion is that all considered it isn't worth the effort and risks for our safety and for the battery life.
Temps we like, our batteries like..Easy to remember. 60-80f at 60-80% charge.
Source ….my 30years in RC. Diligently kept batteries last longer and carry more capacity.
There’s no reason you can’t put your bike battery next to the the AAAs and AAs from 1996. Look behind the I can’t believe it’s not butter spray, Uncle Burl brought for himself Thanksgiving 97’ . They are still there.
It’s yours keep it where you want😂.
Took my battery out of the bike (kept in the garage) to get some heat into it today before I went for a ride. It was around 7C in the garage this morning and probably colder overnight, it took around 4hrs to bring upto room temp (approx 17-18 C). What I'm trying to say is batteries have lots of dense mass and are like defrosting a frozen chicken or turkey. Keeping one in the fridge (unless the fridge is warmer than wherever it's kept) is ridiculous.
Although cold temps are not good for discharge rates in the short-term, I mean the EV will not make as much power at that moment, it definitely prevents degradation.
But really room temperature is good enough. If you can get your battery out of a hot garage during the summer it'll last the bike's useful lifetime easily with very low degradation.
High temperatures on the other hand, anything over about 85° f, starts to degrade a battery. Once you get over a 100' F, it's pretty significant degradation. Where I live in Texas my garage is over 100° for 4 plus months of the year. That's why the removable battery is useful on my Relay so I can just pop it out and bring it into the house. In the winter I don't bother.
The reference to "keeping it in the fridge" likely came from a comment I made.
Long term cold storage, like over the winter where you are not using it, of lithium batteries in a cooler/fridge, prolongs the life of the battery by slowing SEI (solid electrolyte interphase) growth.
The same chemical state that cause a li battery to be damaged during charging and discharging in cold temps, also preserves it when it is not in use.
Pretty common practice with high dollar lithium accumulators.
Does it hold value for e-bike batteries ?
Not for me personally, I buy a new bike or two every year.
And the batteries are relatively cheap.
Part of the issue manufacturers have with this is that people are dumb. They will pull that battery out of a cooler and attempt to use it before it has warmed sufficiently, or worse, attempt to rapidly warm it, to go on an impromptu ride.
The construction techniques used with current e bike batteries leaves something to be desired as far as tolerance to rapid thermal swings. The individual cells being encased in tight fitting aluminum housings, connected with foils and spot welds is not ideal to cope with thermally driven mechanical stresses.
Storing batteries in the fridge used to be common advice, but for most modern batteries, it’s not recommended anymore.
For alkaline and lithium-ion batteries, refrigeration doesn’t improve lifespan and can actually create problems. When batteries are taken out of a cold environment, condensation can form, which increases the risk of corrosion on the terminals and internal damage, especially if they’re not in airtight packaging.
Lithium-ion batteries (phones, laptops, power tools, etc.) are best stored:
At room temperature (around 15–25°C / 59–77°F)
In a dry environment
At 40–60% charge if stored long-term
Cold temperatures can temporarily reduce performance, and repeated temperature changes are more harmful than helpful.
The only cases where temperature-controlled storage makes sense are industrial or bulk battery storage scenarios, where conditions like humidity, fire risk, and chemical stability are carefully managed not a household fridge. If you need to know about Lithium Batteries Storage, so you can read:
Pardon me, but that's for a different reason: because for various reasons they need to stay within a certain temp range while in use. Storage is different.
Yes and no. A car won't sit in storage and let the battery cells go cold because they're not being used. While in storage the car with automatically keep the batteries within temps that will not hurt them.
If you put a car in -30 , see how often the battery warmer turns on. Even when the car is; off and in park.
because the car must be ready in minutes in case you need to use it. For an ebike winter storage - and we are talking about this - is different.
I invite everyone to refer to the original, published technical papers, not to websites misinterpreting or simplifying things to obtain a few more clicks.
Yes and its laughable at most.
You should always pre-warm your battery in the microwave if possible. If you have a fixed battery like me, using a hair dryer for 15 mins before a ride knocks 5 minutes off my Strava times.
Yeah I only KOM when I nuke my battery
I really hope this was meant as a joke. Heating batteries in a microwave is extremely dangerous. Certain components can overheat, expand, and fail, potentially causing short circuits and severe damage to the battery. There’s also an added risk from eddy currents induced by the microwaves, which can create sparks in metallic parts and even start a fire.
On top of that, microwaves only heat certain molecules—mainly water—by resonating with them at about 2.45 GHz. That’s why dry materials like glass stay cool while food heats up quickly. A battery is not designed to absorb energy that way, so the only likely outcome is damage.
In short, please don’t try this. It’s dangerous and serves no useful purpose.
Not at all, I do it most days
Solid tip. I usually go one step further and preheat mine at 800 W until it smells like victory. Really wakes up the electrons.
I expect it's a joke.
Please do not take any of these suggestions seriously (can't believe we seriously need to say this) as most if not all of them are dangerous and definitely not to be tried.....
    Join 43,139
