Brake pressure question
pagheca
Somewhere in the Galaxy
Me again,
There’s also one thing I can’t figure out: every time I take the wheels off, the brake system loses pressure. What’s weird is that after a few squeezes of the lever, pressure comes back and the brakes feel normal again. Since it’s a closed hydraulic system (and there’s no visible reservoir like in a car), I don’t get how that’s possible. Any ideas?
Cheers
thanks for the quick answers, guys.
Yes, maybe there is air, but why the system works after a few squeeze of the levers if there is air inside?
And yes, they are Shimano.
I spoke with customer support, and they told me that the brake issue is normal. It can happen when the bike is laid on its side (as I did to transport it in the car) with the wheels removed, and then returned to a vertical position.
They weren’t able to provide a detailed technical explanation, but I suspect it might be due to air bubbles moving around and then back up into the small reservoir located above the brake lever.
Does that sound reasonable to you?
You could try a "ghetto bleed" first.
Zip tie the levers to the bars as tight as you can and leave them over night.
I think I will do the bleed soon, thanks. Is it something feasible at home? Does it requires specialized tools?
I am quite good at mechanical works but no experience on this.
Bleeding brakes is just a common part of owning a bike. Even when your brakes are running fine, you should bleed them periodically anyway to keep the system free of contaminants. Since you're already competent with other mechanical contraptions, you'll get this figured out. It might take a couple times before you're a pro, but anything that requires skill is like that.
Me again,
Cheers
Most likely, when you remove the wheel/rotor the process slightly moves the caliper pistons away from the rotor. When you reinstall the wheel, the first movement of the brake level is moving the pistons back to the original position of the pistons/pads. It may feel like a loss of pressure.
When you remove wheels always put pad spacers in the calipers. Just saying.
This^^^.
Magura brakes need constant bleeding. Shimano brakes not so much. A lever bleed doesn’t require much; 2.5mm Allen key (or torx), small bleed funnel and a bit of mineral oil. Once ready for a lever bleed, pump the brake lever and watch for bubbles to rise in the funnel. When the bubbles stop …you’re done.
Remove the funnel, replace the bleed screw, test the lever action. Takes about 4:52 seconds for each side …unless you’re really good at it. 😉
You are totally right @irie!
Actually this was suggested to me long ago by my ebike's seller. I just forgot the spacer at home the other day. It is also risky because if you must repair your tyre you risk not to be able to insert the wheel anymore in the brake pad if you don't have the tools with you.
Don't agree with that. I don't get any issues with mine on any bike. Bleed once or twice a year, depending on use.
I can’t explain it.🤷🏼‍♂️
Every 1-2 months I must do a lever bleed. But I love the feel and action. I’ll put up with some more maintenance and regular servicing. However the MT8’s on my Fuel EXE don’t need as much attention.
I gladly traded my Shimano brake system’s for some MT7’s. The guy hated the MT7’s…I didn’t. I’ve had some bad Ju-Ju with the Shimano brake systems.
Half the bikes in my little circle have MT7’s. Most of us need a regular lever bleed.
Me again,
Cheers
Pistons may not be fully retracted and system needs to be re-bled.
I store my bike vertically, hanging on the front tire on a wall. Never a problem with brakes.
I flipped my bike upside downrecently and remove the rear wheel to clean the sprockets and chain.
I’m sure this got air in the system, but it didn’t show up until a couple weeks later. I don’t know why. One day I started a ride and the brakes went to nothing. I could pump up a little at first, but it quickly went to nothing.
In the process of bleeding the brakes at the rear, the first pull of the syringe was a huge amount of air. I was shocked. The fluid was a dirty, dark gray as well. I’m told that is due to overheating or oxygenation. I’m going with oxygenation.
The bike is two years old.
It’s been working great so far after five or six rides.
Hope that helps. Good luck.
  • Like
Reactions: ncs
Me again,
Cheers
Bleed the brakes, air will get in there a tiny bit at a time.
