Bafang M500/M600 Tuning & The BESST Tool
I am getting super confused about what to do with my new bafang m600 motor driven emtb. I hate the torque sensor/ramp up and crappy battery life which I think is partially due to the power wastage.
So I'm on the search for what I can do about that. I'm wondering if I should try the luna X1 firmware or another. I was hoping for a guide but the best github I found: Bafang_M500_M600/Firmwares at main · OpenSourceEBike/Bafang_M500_M600 seems to have removed all the custom firmware. I have a canbus setup and changed a few basic settings but from what I can tell most settings are not available on the m600. Is there any way to unlock more settings or does bafang basically have to provide each firmware as requested?
from what i have learned , m600 has no options to change unless u have special firmware . its behaviour depends on the fw so i had motor that behaved differently - you have to try different fw's to try their internal settings - not available for enduser sadly ...
Yeah thats where I got to. Thanks for confirming. Its weird that some motors are so locked and others are not.
I've installed the firmware from kiwitourer from page 12 here in this thread. I drive my m600 for two years already and it is very good.
I'd like to know if there's a better firmware version available than this one.
Hello It is 48V and 18A firmware. There is some firmware with 20A
And looks like you have some latest firmware, I dont have your v76.3 with FC3.3
Have just 2 firmwares FC3.3 , but I think also FC3.2 would be compatible with your motor (not 100% sure).
Last marked is FC3.3 and for 52V.
Can I use the firmware luna_x1_firmware__74963.bin?
You can try. ;)) But is very old. And I guess will be set for shunted controller.
Be carefull about roll back. You can loose your v76.3 if you dont have it as bin file.
    672K
