YesDoes a CEF69-2 have the holes in the side of the head tube for cable routing?
option cables by the direction or by the sidesDoes a CEF69-2 have the holes in the side of the head tube for cable routing?
I don't think soCan the cef69 frame use dual crown fork?
If you have both options when ordering itDoes a CEF69-2 have the holes in the side of the head tube for cable routing?
CEF50-2 M820 motor with DP C245 display. CEF50-3 M820 motor with DP C030 display. CEF55-2 M820 motor and DP C030 display. CEF69 M510 or M560 motor and DP C030 display.Does anyone know the difference between the CEF50, CEF55, and CEF69 frames in terms of their intended use? Which of these is best suited for gravity riding?
Thank you, but this does not resolve my doubts regarding the field of use of one rather than the other. That is, I would not like to make the choice based on which motor to use, but I would like to make the choice knowing that one is better for descending and the other is better for climbing, both in terms of geometry and the components I could install.
CEF50 and 55 are more agile for descending due to their weight, and CEF69 is a great climber due to its power.Thank you, but this does not resolve my doubts regarding the field of use of one rather than the other. That is, I would not like to make the choice based on which motor to use, but I would like to make the choice knowing that one is better for descending and the other is better for climbing, both in terms of geometry and the components I could install.
For example, my current choice would be the CEF55, because I can have greater rear travel (up to 180 mm), even though I will then mount it with 160 mm rear travel (which cannot be done with the CEF50).
Based on this, do you think my choice is correct?
How can I find the pricing on these frames and how would one go about ordering one?CEF50-CEF55 with Bafang M820 battery, 480-835 Wh, and optional 280 Wh extender
CEF69 with Bafang M510 motor, 480-835 Wh battery. option cables by the direction or by the sides.Private information available.
View attachment 164648 View attachment 164649 View attachment 164650 View attachment 164651 View attachment 164669 View attachment 164670
You have a private account. I am a sales representative for the brand in Spain.How can I find the pricing on these frames and how would one go about ordering one?
where you bought itI just ordered a CEF69 see how long and shipping takes to Australia
Yes off Jean, Top Bloke and with Custom Paint and M510 with 110NM 3.0where you bought it
Te llamas Nereo ?Yes off Jean, Top Bloke and with Custom Paint and M510 with 110NM 3.0
where you bought it
Nar its Peter.Te llamas Nereo ?
I also just ordered a cef69 from Jean earlier this week. I'm in the US. I'm excited but know I'll have to be patient.I just ordered a CEF69 see how long and shipping takes to Australia
What forks and Shocks you going with? Are you going to do Mullet.I just wanted to add that Charly reached out to me privately and worked on quoting and pricing the kit that I wanted. It was a very nice experience working with him. Then, I placed the final order with Jean from szzs.
Planning on 29er front and back. Fox 36 performance 160mm up front and might get a 170 air spring for it. Super deluxe 205x60 in the rear.What forks and Shocks you going with? Are you going to do Mullet.
Sounds Good, Ill stick with the Mullet im not to tall so i need the extra help to through around a bikePlanning on 29er front and back. Fox 36 performance 160mm up front and might get a 170 air spring for it. Super deluxe 205x60 in the rear.
