New CEF69 bafang m510 and bafang m560 and cef50 bafang m820 frames
Charly
España
CEF50-CEF55 with Bafang M820 battery, 480-835 Wh, and optional 280 Wh extender
CEF69 with Bafang M510 motor, 480-835 Wh battery. option cables by the direction or by the sides.Private information available.When ordering, say Charly for a discount of about 20 USD off the final price.
IMG_7724.jpeg IMG_7722.png IMG_7716.jpeg IMG_7714.jpeg IMG_7756.jpeg IMG_4113.jpeg
Does a CEF69-2 have the holes in the side of the head tube for cable routing?
Does anyone know the difference between the CEF50, CEF55, and CEF69 frames in terms of their intended use? Which of these is best suited for gravity riding?
CEF50-2 M820 motor with DP C245 display. CEF50-3 M820 motor with DP C030 display. CEF55-2 M820 motor and DP C030 display. CEF69 M510 or M560 motor and DP C030 display.
Thank you, but this does not resolve my doubts regarding the field of use of one rather than the other. That is, I would not like to make the choice based on which motor to use, but I would like to make the choice knowing that one is better for descending and the other is better for climbing, both in terms of geometry and the components I could install.
For example, my current choice would be the CEF55, because I can have greater rear travel (up to 180 mm), even though I will then mount it with 160 mm rear travel (which cannot be done with the CEF50).
Based on this, do you think my choice is correct?
CEF50 and 55 are more agile for descending due to their weight, and CEF69 is a great climber due to its power.
I just wanted to add that Charly reached out to me privately and worked on quoting and pricing the kit that I wanted. It was a very nice experience working with him. Then, I placed the final order with Jean from szzs.
Scott, thank you for trusting the SZZSbike brand with the CEF 69. We will soon distribute from Spain. Now it's your turn to assemble it.
What forks and Shocks you going with? Are you going to do Mullet.
Planning on 29er front and back. Fox 36 performance 160mm up front and might get a 170 air spring for it. Super deluxe 205x60 in the rear.
    Join 43,138
