3d Printed Titanium motor through bolts
Oooooh....
Mounted up ready to see if they will snap like carrots....
let the testinb begin.
Very nice. What did they end up costing?
I don't think they will snap like carrots. But snapping like low grade aluminium would arguably be worse. I doubt they are significantly stronger than 7075 ones would be.
7075 if 550mpa uts 3d printed ti is 950mpa. So almost double the strength of 7075.
They are between grade 9.9 and 10.9 bolt grade strength.
Ref sintered titanium bolts. As long as they are strong enough for the job, you might as well take the weight saving if you can afford it. I'd watch out for the bolts fatiguing.
QUESTION to Chat GPT
Is sintered titanium stronger or weaker than machined or forged titanium. Intuitively, it has to be weaker, but by how much?
ChatGPT said:
You're right to be sceptical about the strength of sintered (powder metallurgy) titanium compared to forged or machined titanium. Here's a detailed breakdown, including approximate strength differences:
🔧 Types of Titanium Processing
Method
Description
ForgedShaped under high pressure and heat, aligning the grain structure for maximum strength.
MachinedCut from a billet (often forged), retaining full material properties.
SinteredPowdered titanium is compressed and heated below melting point to fuse particles (like 3D printing or PM techniques).
🧪 Mechanical Properties Comparison
Let’s compare Ultimate Tensile Strength (UTS) and Yield Strength for common grades of titanium processed in different ways.
Property
Forged/Machined Ti (Grade 5, Ti-6Al-4V)
Sintered Ti (Grade 5 or CP Ti)
UTS~900–1100 MPa~600–850 MPa
Yield Strength~800–950 MPa~500–700 MPa
Elongation (ductility)~10–14%~2–6%
Fatigue resistanceHigh (due to grain alignment)Lower (due to porosity)
Key Point: Sintered titanium is typically 20–40% weaker in both yield and ultimate strength, with significantly worse ductility and fatigue resistance.
🔍 Why Sintered Titanium Is Weaker
  1. Porosity: Even with advanced techniques (like HIP—Hot Isostatic Pressing), sintered parts usually retain some porosity.
  2. Grain structure: Forging aligns the grain, enhancing strength; sintering creates random grain orientations and possible grain boundary weakness.
  3. Impurities & Oxides: More likely during powder processing.
  4. Surface finish & defects: Sintered parts tend to have rougher surfaces unless post-processed, which can reduce fatigue strength.
📊 Real-World Example (Ti-6Al-4V)
Process
UTS (MPa)
Yield (MPa)
Elongation (%)
Forged + Annealed950–1100880–97010–14
Sintered + HIP750–850650–7004–6
Sintered (as-built)600–700500–6002–4
🧠 Summary
  • ✅ Forged/machined titanium is stronger, tougher, and more fatigue-resistant.
  • ⚠️ Sintered titanium is 20–40% weaker in strength, and much worse in ductility and fatigue, unless post-processed via HIP or similar.
  • 💡 Sintered parts are still excellent for complex shapes or biomedical implants, where form is more important than maximum mechanical performance.
I can't see them breaking from a simple over-load. It's going to be a fatigue failure (if anything). If the layers are across the bolt then that's a lot of potential fatigue stress raisers, inclusions, and possible porosity sites. If the layers are along the bolt then that seems less worrying.
7075 does have a lower UTS and Yield, but a good billet part with a good finish should have very few sites for fatigue to start from and would be half the weight again.
But personally I'd look elsewhere for weight savings, especially as I am sure these were eye wateringly expensive?
Method
Description
Property
Process
UTS (MPa)
Yield (MPa)
Elongation (%)
🧠 Summary
You've asked the wrong question unfortunately. Try selective laser melted, might be closer to the mark.
Also, compare it to the OEM steel bolts, obviously.
I think it would be smart of Bosch to add Ti bolts thoughout to the CX-R package. At the oem level it would cost very little, it's trick, and maybe with all the bolts going Ti they could knock off 100+ grams.
Method
Description
Property
Process
UTS (MPa)
Yield (MPa)
Elongation (%)
🧠 Summary
AI isnt always correct....
PS I was also wrong. They are 950mpa yeild and 1100mpa uts.
This big question are they as strong as the bolts i've removed? The answer is a about 100mpa less.
Lets see it they work. Only one way to find out!
yep. They are approximately 100mpa UTS less. I suspect there's a 3 or 4 to one safety factor on the oe bolts. So i'll be reducing that a bit. Time will tell.
Hope your engineering is way better than the Subsea 7 ones I worked with .
Talk to 3d printing guys and they say the grain strucrture is uniform an as strong in both axis and is superior to a machined part with has higher strength properties in the directlon of the grain.
Its all theoretical until tested. So now let the testing begin.
Hehehe.... Less at stake if i stuff up here... This is not my first foray into designing and print TI fasteners. The first like worked out. Lets see if these to do......
It's also worth stating when ever i've pushed the limits of engineering designs. There's always been people saying "wont work" "its gona break" 'can't Do it" "i wouldn't" most of the time they are wrong and it works out.
Sometimes they are right... and my crazy shit doesn't work.
I have an open mind about this. The strength checks out on paper. How does it go in a real world test????? lets find out.
Wish you well. It's all over my head 3 d printing etc ???
Assuming you aren't huge, and/or don't ride super hard, I would guess they will be fine, but... What did they cost? For the third time of asking?
The cost is dependent on volume. I wont publish the cost just incase I decide to sell them as a product. For now they are a decadence for shits and giggles and just plain cool having something of my own designed on the bike.
We'll see if hold up to long term testing
78kg and this was me last week. I'll be testing these off this drop.
The benefit is lighter weight and many motor bolts are custom sizes. So you can't readily go and buy a ti alternative.
is it really that hard to make them?
I've seen bike mechanics on YouTube make their own bolts from a cylinder of metal.
surely almost anyone with a lathe can make one
Fair enough not quoting a price, but were they really cheaper than machining them? Seems unlikely.
I don't have a lathe. To pay someone to set up and run a small batch on a cnc lathe is expensive, 3d printing is cheaper for small batch test runs.
Also the average home hobbyest aint going to have the tooling to broach of machine the hex.
For me yes, its more cost effective to 3d Print. If i had a lathe with appropriate tooling then no. But I don't.
For a production run. Spitting these out on a lathe would be far cheaper than 3d printing.
But you've turned the threads surely?
These Ti bolts. Do they come with a specialty drill bit for when they cold weld themselves to the mounts ?
These new Bosch mounts use little nuts which it looks like he has also printed in Ti, so as long as there is a bit of anti-seize on there should be fine.
Yes i printed the nuts and yes I've lubed them up......
