Plummet
Flash Git
Before I rant on about weight weenie parts. I refuse to compromise performance.
As an example, If a heavier coil shock is what's required, that's what i'll use.
What I am interested in is all your weight weenie hacks that dont compromise performance... or increase performance.
So far my weight weenie hacks consist of the following
Light weight carbon frame with different battery options. That's probably the best hack.
PS I'm not interested in mid power bikes.
400wh battery, Saves 1kg from 600wh and 2kg from 800wh
Bontrager RSL one piece handle bar/stem Saves 200 grams from bar/stem combo's
Enve Foundation wheelset. Saves around 300 grams from a equivalent alloy wheel set. Plus these wheels are super freaken strong. They take a beating so its also a performance upgrade too.
That's about it for weight reductions bits, The rest is standard.
I'm about to dive into titanium bolts. Probably can save another 100 grams on bolts.
The front chainring is steel so i can save another 100grams there.
I need to start looking at seats too, maybe lighter pedals.
Then long term i plan on designing and 3d printing some TI cranks.
Current bike weight with 400wh inc pedals is 21.8kg.
I'd be delighted it i could get that around the 21kg mark
To answer the question that inevitably will be asked. "why bother reducing weight on an already heavy e-bike"
The answer is the lighter it is, the more playful it is and the more it feels like an mtb.
