TQ just launched the HPR60, it’s based on the TQ HPR50 that was came out in 2022. The HPR60 is now rated at 60 Nm and 350 W, compared to the 50 Nm / 300 W of the HPR50. It’s not just the power that is upgraded though. Read more ...
Yeah sorry. Didn’t mean to imply backwards compatibility, just maybe better range from software60NM would be a sweet spot for me. The HPR50 whilst very good is just a little undergunned for my weight 110kg kitted.
I wasn't anticpating backwards compatibility
Sorry, wasn't directly replying to you. I understand what you meant.. The faster charging in the latest update was a nice surprise. So hopefully some updates to come for the older motors/batteries.Yeah sorry. Didn’t mean to imply backwards compatibility, just maybe better range from software
Yep agree the power/torque changes are not significant, the efficiency change (if it really is more efficient and it's not just fluff) is the big one.My 2 cents…..As an owner of both a Scott Solace eRide (e-Gravel) and Scott Lumen (e-MTB) I don’t really see the huge appeal of the HPR60. I already downrate my e-Gravel to 250 max specifically to manage the battery. You just don’t really need more than 300w max on the road. It limits at 28 mph regardless.
As for e-MTB, I get that they are trying to keep up with trend of larger watts. But 50w doesn’t move the needle. To me the real benefits are the ~20% improved efficiency as battery capacity has always been the limiter for me. I wonder how much of this is hardware vs software…..and if they quietly push an update to HPR50 with the efficiency improvements. That would be the GAME CHANGER for me as I am always managing my assistance levels on the e-Gravel.
Also, It’s bigger on the bottom now, so going to create frame clearance issues on existing models. I don’t see how HPR-60 will appeal to road/gravel frame designers that are all about sleek/low profile appearance. So are they going to keep selling HPR50 and 60 models concurrently?
this is where I am. The +10nm is mostly just icing, for me its the wider adoption of the 580wh battery that is the real drawI would just wish my EXe would the 580Wh battery
Also sounds like some significant efficiency improvements, which could get a lot more range out of existing batteries!this is where I am. The +10nm is mostly just icing, for me its the wider adoption of the 580wh battery that is the real draw
Constant error messages too. But TBH every brands walk mode sucks and we've had worse.I find walk function useless or don’t work.
Also hard holding down the button while trying to push the bike
HPR60 is 20% more efficient according to this review/testing.And also unless it’s more efficient, the hpr60 would drain the 360 even faster.
The efficiency of an electric motor is around 90% so if the original motor had an efficiency of 90% the new one might be around 91.8% which sounds less impressive than a 20% improvement. In real world that might translate to a 1-2% range increase all other parameters being equals, still good to takeHPR60 is 20% more efficient according to this review/testing.
I'm skeptical that would translate into 20% more range, all other things being equal. However- even if the range is the same but it does not self-limit as much as the current HPR50- and have higher torque too- that would be a cool upgrade.
They performed a range test against the old motor and recorded the below. Far more than a 1-2% increase.The efficiency of an electric motor is around 90% so if the original motor had an efficiency of 90% the new one might be around 91.8% which sounds less impressive than a 20% improvement. In real world that might translate to a 1-2% range increase all other parameters being equals, still good to take
Despite being tested with the bigger, heavier 580 Wh battery, and the same identical tires and air pressures, the HPR60 in the Yeti used over 20% less energy – despite the bike being nearly 10% heavier than the Canyon. The measured energy consumption came in at just 25.65 Wh per 100 vertical metres, which is remarkably low, especially at full motor support.
In absolute terms, our test rider climbed nearly 2,200 vertical metres on the 580 Wh battery with an average rider output of 175 watts. For comparison’s sake, the HPR50 drive combined with the 360 Wh battery managed just over 1,050 metres under nearly identical conditions. Based on those figures, the HPR60 of the Yeti should theoretically achieve around 1,350 metres of elevation gain with the smaller 360 Wh battery – a clear and measurable improvement.
That translates to a 27.2% increase in efficiency for the Yeti compared to the Canyon, calculated based on elevation gained per unit of battery energy consumed. This figure accounts for both the weight and speed differences between the two bikes.
It would drain battery faster if the hpr60 were not more efficient than the hpr50. But it supposedly is a lot more efficient. So it is just a matter of getting the hpr60 to talk to the old batteries, dropping it in with a new control screen, and seeing how it does. Maybe they will even go higher power at some point, but one suspects they are maxing out this form factor first.The 580Wh are definitely larger than the 360Wh, so no backwards compat there.
A mtbr range review of all lightweights had the hpr50 being the lowest, the specialised 320Wh being better as is the 400+ rise60s
But I do love the output feel of my hpr50
This may be true. I would like to highlight that no one seems to be outlining a framework for how much power is "enough". As my hot rodding friends say, "Fundamentally, you get used to any amount of power." I can see using higher and higher multiples of rider power output with age, as riders become less powerful. But to me if one rider is on a device putting out 2x rider power, while the other rider's kit is putting out 0.5x rider power, they are not really having the same experience. Rather like the people riding the lift whilst I zigzag up the chute on skins. Related experiences, but not meaningfully discussed in the same conversation. The same comment applies, but less markedly, to motors with different amounts of maximum torque. It is sort of like swimmers who race with fins and full face snorkels, vs swimmers who race with goggles only. Or archers vs air pistol shooters. Not that all riding is competitive of course. But really the writing about these devices should be categorized by power output to provide any meaningful context. Thanks for this thread. Enjoy.I think the HPRs are great for many users, unfortunately it wasnt for me.
Just have to give a word of warning for prospective buyers, the 50nm is not really representative of the power levels. At 100W of rider input it is significantly less powerful then the spec 1.1 35 nm motor (see velomotion review). Just wanted to give some context for possible buyers, I think it has many other great charecaristics.
ould just wish my EXe would fit the 580Wh batS
SameI would just wish my EXe would fit the 580Wh battery
