• Warning!!
    UK Pedelec Law
    Worldwide Laws
POLL: Do you want to be able to derestrict your Amflow PL?
Do you want the option to remove the speed limit/derestrict your Amflow PL for use on private land?
  • Yes
    Votes: 43 60.6%
  • No
    Votes: 28 39.4%
  • Total voters
    71
  • Poll closed .
A surron is in the multiple KW and doesn’t have pedals. Hardly similar at all
Yes. A SurRon has a throttle. It's not the same. But the wheel spin you can generate if you set over run to maximum and select Boost for 60 seconds, feels like a motorbike.
Do I ride it this way? No. I was just testing the bikes limits. I'm just saying that if you derestrict it and set all setting to maximum, the bike can feel like a SurRon.
Yes I own Electric Motorbikes. Yes I have ridden the SurRon. And the Amflow derestricted accelerates faster to 30kph than my Electric Motorbike, which has a 5kW motor, because the Motorbike has no gears, and weighs over 100kgs. And with the SRAM XO transmission, and Smoothshift on the Amflow. I can shift at full power.
BTW. My E_Motorcycle. Customised for me like my Amflow. 🤣
My Shimano EP801 is set to Class 3 when I ride on the road. And the 45kph is more than required. But it's no where near the Amflow. I can wheel spin on concrete with the Amflow.
Sounds like the Amflow will have a lot more power then the gen4 Sworks. Someone said after 20mph it drops down to 250w between 20-28mph
I ride a ep801, in C3. Im on that limiter all day. I dont want the Sworks if im only in a slightly faster rig.
So your saying the Amflow nz mode is a beast over 20? and i stand corrected?
Anyone successfully derestricted their Avinox motor with VPN recently?
Heard rumours that it has now been stopped ?
getting mixed results. And it now depends who you purchased it from. Mixed results there too. Not sure if the VPN can bypass that aspect. many still say they are unrestricted using HK or NZ on authorized purchases
