2024 Strive:ON
Why would you go for the Tech 3 when the Tech 4 is a significant upgrade?
Hello,
I wouldn't, sorry it was a typo.
I'd definitely go for the Tech 4 / V4 and have got those on my Strive:On.
I've got Tech 3 on the manual bike. They're ok but the Tech 4 levers are much smoother with more modulation.
Hi. I’m sure the Q factor for the Strive:On cranks is buried in this thread somewhere but with 51 pages I’ve given up searching.
Anyone know the correct Q factor ? Thanks
Bosh motors often feature cranksets with Q factor from 168mm to 174mm
Cheers dude, I bent a Miranda crank today on a tree stump so need to invest in another set. Fancy something a bit more robust but not spending £100’s on Hope
No problem . yes that's why it's better to have soft crank arms like Miranda have so they fold instead of broke the engine.
Yes hope is very expensive , i am looking for new cranks aswell and looking at the Race face affekt cranks , they look good and are not so expensive .
Do you now what offset the strive should have ? . When I looking for new cranks i can choose 21 mm offset and 26 mm offset
I don’t. I’m sure I posted the offset & Q factor on this thread somewhere last time I bought the Miranda’s, but searched yesterday and couldn’t find anything 😅
The 26mm offset will definitely work, the 21mm offset might not work.
I replaced with E*13 Helix Race e-spec Cranks 26.5mm offset and they work well.
I haven't tried anything less than that.
Thanks , I googled and looked for the answer but couldn't find it.
Haha okey , ye i searched to here and on google but couldn't find it either 🤣
Another question which I can't find the answer for when searching this thread!
I need a replacement chainring. FSA Megatooth 36T is the orginal, I'm looking at a Raceface as a replacment. Available in two sizes, 52 or 55mm. Anyone know which size I need ? Thanks
It's a 55mm chain line on the Strive:On
Nearly two years with my Underdog. Still very happy. I made some small changes which makes the bike even more fun to ride:
- Trickstuff brake pads and HS2 discs
- e13 155mm cranks
- Title bar with 50mm rise
- ochain "chainring"
- Conti tires with DH casing (supersoft front)
