I don't know ? i havn't smartphone (and e-tube off course), i use E-tube pro with shimano interface and yes the E295 are registred (and can't be cancelled, unlike all others errors)Have you seen the error in the E-Tube app?
What about my YT Decoy Max? As standard it comes with Crank Bros hubs that do not have Shimano centrelock hubs, note does my wife’s Decoy, that has Ringle hubs, again with a 6 bolt pattern. In fact none of the YT e-bikes have Shimano hubs or centrelock.It's not a communication thing. It's a magnet signal thing. What's causing the the error is the pulse, in the speed transducer, from the magnet is different. Most likely is it's a double pulse, created by inconsistent voltage levels as the magnet passes in front of the speed transducer.
Regardless. The induced voltage in the speed sensor obviously needs to be within a very tight tolerance. And only running a Shimano Centrelock hub, will ensure the spacing created when you mount the Shimano Magnet is identical to the original wheel. And will thus produce an identical signal in the speed sensor.
The E295 error is linked to the modification of transmission (wheel diameter, Nb of teethes), not the magnet of the speed sensor or the brand of the hub.My bike came with Hunt wheels as standard from new with Hayes disks and magnets. I don't think it matters what wheels and disks the bike has from new if it is set up with those components. The problem seems to arrise if you fit anything other than what was set up by the manufacturer as it would appear that even a 0.5mm difference in airgap/lateral positioning to the magnet must be enough to trigger the anti tamper software
What about when you upgrade your brakes and need to fit thicker rotors, especially as lots of brakes are now coming with 2mm+ rotors? Will this ruin your bike?So what's the verdict? one can't use custom wheelset? I have Rise 2023 with EP801 and DT350 hubs paired with Bosch magnet. Anything I need to change? (not going to use shimano hubs)
It was discussed in length on the German Pedelec forum by Peter Mayer who writes de-restriction software for the EP801. It's caused by pulses from the magnet and sensor alignment producing double pulses.The E295 error is linked to the modification of transmission (wheel diameter, Nb of teethes), not the magnet of the speed sensor or the brand of the hub.
Manufacturers are working with Shimano to ensure their systems don't produce the double pulse. So as I said. You can use any wheel set. But if you modify your wheelset, there is a chance that the magnetic field from the magnet is interfered with.What about my YT Decoy Max? As standard it comes with Crank Bros hubs that do not have Shimano centrelock hubs, note does my wife’s Decoy, that has Ringle hubs, again with a 6 bolt pattern. In fact none of the YT e-bikes have Shimano hubs or centrelock.
The thread was started, proposing that the EP801 is a problem. What I am showing is that the motor is not the problem. The problem occurs when you modify the rear wheel. So I propose how you can still change the rear wheel with zero risk of bricking your motor.Yeah, I’m never using Shimano hubs. I can’t stand centrelock. And if I’m upgrading my wheels from Ringle or Crank Bros I’m definitely not downgrading them to Shimano hubs when Hope an option.
I was just questioning how numerous bike companies can spec and sell bikes without a Shimano hub or centrelock rotors without causing the problem. By your reckoning you’re also suggesting that people can’t upgrade or change the brand of their brakes which seems preposterous in this day and age.The thread was started, proposing that the EP801 is a problem. What I am showing is that the motor is not the problem. The problem occurs when you modify the rear wheel. So I propose how you can still change the rear wheel with zero risk of bricking your motor.
If you are confident you can modify the rear wheel and not brick your motor, because you have designed a wheel that doesn't produce magnetic interference to your speed pick up. Then install whatever you want. But if you want to change your rear wheel and are not that electrically and mechanically minded. Then using all Shimano centrelock hub, rotor and magnet should insure a trouble free conversion. I have clearly shown why above.
But it's 100% up to the individual, their installation skills, and their appetite for risk. I'm just proposing a solution.
I have two set of wheels, neither have original rotors, or magnet what came with bike.My bike came with Hunt wheels as standard from new with Hayes disks and magnets. I don't think it matters what wheels and disks the bike has from new if it is set up with those components. The problem seems to arrise if you fit anything other than what was set up by the manufacturer as it would appear that even a 0.5mm difference in airgap/lateral positioning to the magnet must be enough to trigger the anti tamper software
Just swapped my rear rotor on DTSwiss wheel with Specilized magnet on it, to Galfer rotor with Galfers own magnet on the rotor. I have now 2mm thick rotor instead of 1.8mm. No other effects.
