Here’s what grok thinks probably a lot has come from here:
Since the Specialized Turbo Levo Gen 4 has not been officially released or detailed as of March 22, 2025, any specs for it remain speculative. However, based on trends in the eMTB industry, Specialized’s past Levo iterations, and chatter from enthusiast forums, we can make some educated guesses about what the Gen 4 might offer. Specialized tends to refine their designs incrementally while pushing boundaries in motor performance, battery capacity, and geometry adjustability, so let’s break it down:
Frame and Suspension
- Material: Likely to remain a FACT 11m carbon fiber frame for high-end models (like the Pro or S-Works), with an alloy option for more affordable trims (e.g., Comp Alloy). Specialized has stuck with this approach for weight savings and stiffness.
- Travel: The Gen 3 Levo has 150mm rear and 160mm front travel (mullet setup). The Gen 4 might stick with this for its “do-it-all” versatility, though some speculate a bump to 160mm rear travel to compete with newer enduro-focused eMTBs like the Orbea Wild or Pivot Shuttle AM.
- Geometry: Expect continued use of S-Sizing (S1–S6) with adjustable geometry via flip chips and headset cups. The Gen 4 could refine this further, possibly offering a slacker head angle (around 63–64°) or shorter chainstays (closer to 440mm) for improved agility, aligning with modern trail/enduro trends.
Motor
- Current Gen 3: Uses the Turbo Full Power 2.2 motor with 90 Nm torque and 565 watts peak power.
- Gen 4 Possibilities: Rumors suggest a shift to a new Brose motor (e.g., the Drive 3 Peak with 95 Nm torque and 410% pedal assist) for better reliability and power, as Specialized has historically partnered with Brose. Alternatively, they might tweak their in-house motor to hit 100–110 Nm torque and 600+ watts, keeping it quiet and smooth—key Levo traits. A lighter, more efficient design is also plausible to reduce the bulky bottom bracket look.
Battery
- Current Gen 3: 700 Wh standard, removable.
- Gen 4 Prediction: A bump to 750–800 Wh seems likely, following industry trends (e.g., Bosch’s 800 Wh packs). Some forum rumors even suggest an 880 Wh option with a 250 Wh range extender, though that might be ambitious. The battery will almost certainly stay integrated and removable, with a focus on better weight distribution.
Wheels and Tires
- Wheel Size: The mullet setup (29” front, 27.5” rear) is a Levo hallmark and likely to continue, though a flip-chip for dual 29” compatibility could be added for versatility.
- Tires: Expect Roval Traverse wheels with Specialized Butcher/Eliminator tires, possibly upgrading to GRID Gravity casing for durability over the current GRID Trail spec on some models.
Components
- Drivetrain: High-end models might feature SRAM’s T-Type Transmission (e.g., X0 Eagle) as seen on some Gen 3 bikes, with mid-range sticking to SX or NX Eagle 12-speed.
- Brakes: Likely SRAM Code or Maven series, with 200mm rotors for stopping power.
- Dropper Post: BikeYoke Revive or Fox Transfer, possibly up to 200mm drop on larger sizes (current max is 185mm on some builds).
- Suspension: FOX Factory or RockShox Ultimate (e.g., 36 fork, X2 or Super Deluxe rear shock), with custom RX tuning.
Weight
- Current Gen 3: Around 22–24 kg (48–53 lbs) depending on spec.
- Gen 4 Estimate: Likely similar, 22–25 kg, unless a major motor/battery redesign shaves weight. Lightweight isn’t the Levo’s focus—power and range are.
Tech Features
- Display: The MasterMind TCU (integrated top-tube display) will probably get a refresh—perhaps a larger, color screen with more data (e.g., jump stats from the Levo SL).
- App Integration: Enhanced Specialized app features, like MicroTune power adjustment in finer increments or auto-shifting tied to SRAM’s ecosystem.
- Extras: SWAT tool in the steerer tube is a lock to return, possibly with added frame storage (a la Stumpjumper’s downtube compartment).
Price
- Current Gen 3: $6,400–$13,000 USD depending on model.
- Gen 4 Guess: Expect a 10–20% bump—$7,000–$15,000 USD—reflecting inflation and tech upgrades, with discounts on Gen 3 stock pushing buyers to decide.
Timing and Context
The Gen 3 launched in 2021, and Specialized typically runs a 3–4 year cycle. With 2025 here and no Gen 4 yet, a late 2025 or early 2026 reveal seems plausible, especially as competitors like Trek (Fuel EXe) and Giant (Trance X E+) up the ante. Forum buzz (e.g., EMTB Forums) points to a spring announcement, but nothing’s confirmed.
Wildcard Speculation
Some dream big: a dual-battery setup (switchable 540/800 Wh like Norco), a belt-driven motor for silence, or even a radical frame redesign (e.g., no sidearm, like the Levo SL). These are less likely but reflect what fans hope for.
In summary, the Levo Gen 4 will likely refine the Gen 3 formula: a bit more power (95–110 Nm), a bigger battery (750–800 Wh), tweaked geometry, and the same premium ride quality. Without official leaks, this is a best-guess based on Specialized’s track record and market direction. What do you think—any specific upgrades you’re hoping
