Amflow Customer Support team is here!Amflow Support questions only please
HI AMflow - I am LOVING this bike.
Question:
Was just going to try it, but I'll just ask....What happens if I set the wheel size on the app, to 27.5, but leave a 29 on the back? Theoretically, I would think, it should go a few more mph, or do you sense the wheel size somehow?
OR does setting it to 27.5, reduce the max speed as its set for 20 mph max, on a 29?
Thanks for this outstanding machine. I ride it almost everyday, IT is swweeeet!.
you will get a little bit more topspeed :cool:
Question:
Hi there!
To your question, what happens if I set the wheel size on the app to 27.5, but leave a 29 on the back?
You can indeed do this, but since the system setting does not match your actual wheelset, the system will not accurately record your riding distance. Therefore, we recommend setting the wheel size in the system according to the actual size of your wheelset. If you have more questions, feel free to email [email protected].
Ride safe and Happy New Year!
Thank you to every dedicated rider for your support and trust in Amflow. Since the launch of the Amflow PL series, our development team, along with Avinox, has taken on board a lot of valuable feedback from users. This week, a major software update for the ebike system will be released.
This update specifically addresses some key user experience issues raised by early users, along with significant security updates, to provide you with a more convenient riding experience. Please upgrade as soon as you receive the update notification. We always value the needs of every user and communities actively listen and respond promptly in collaboration with our partner DJI, continuously improving product experience and service quality. We look forward to receiving your feedback after you experience the new software. Thank you for your support and understanding.
Finally, we wish you a Happy New Year for 2025.
The contents of this update are as follows:
【App】
- Adds support for configuring additional parameters in assist modes and optimized visual graph. Set parameters will not be affected.
- Adds support for setting bike inclination angle and unit for gradient.
- Fixed certain known issues.
【Firmware】
- Adds support for configuring additional parameters in assist modes.
- Adds support for pairing heart rate monitor via Bluetooth.
- Adds support of motor safety protection when bike attitude error occurs.
- Adds support of Freehub Pre-Engagement to Experimental Feature.
- Fixed certain known issues and security updates.
Hi.
Is it possible to order the Large with 160mm cranks?
What other third party cranks are compatible?
Thanks.
Hi Entonox,
The Crankset of Amflow PL is DJI Avinox SL Crank (we recommend: M/L: 155mm; XL/XXL: 160mm)
Amflow PL uses an ISIS interface. It is recommended to use the official crank for optimal compatibility.
【App】
【Firmware】
My thoughts on the updated firmware in case you don't read all the amflow posts Post in thread 'Dji avinox- Amflow' Dji avinox- Amflow
Hey @Amflow_Support. Does the following video seem OK?
I noticed on my rides in the techy stuff when you're out of the saddle and putting plenty of force through the pedals there was a clicking, creaking, cracking sound. So I've done a demo of what I'm hearing.
Opinions?
Hello @Amflow_Support team.
Just checking out if those websites are "authorized or official dealers" for Amflow bikes. They are both in USA (supposed to be). Do you recommend or endorse any of them? They might offer brand warranties?
- Ebike Premier
- Ronhack by @Ronhack
Thank you so much for your attention.
Hi enduromtbmexico,
Please kindly know that, for USA, we are under the planning for sale, and for the local dealers, we are in the process of negotiation, for the time being, it is not yet public, everything will be subject to the display on our official website, please keep eye on, thank you for your understanding and support!
Opinions?
Hi ixi,
We have watched the video, could you kindly please try to pedal the crank quickly back and forth, if there is still like before, the gears might collide and make a "da da" sound, similar to gear knocking. that is cause the assist unit has some gaps in its gear system, and this sound won't occur with continuous pedaling, it is normal. if there is any other issues, please contact this email address: [email protected] for help, thank you for your understanding.
We’re excited to join this fantastic community! We are the Amflow Customer Support team, dedicated to providing top-notch assistance and innovative solutions for E-MTBs. Our mission is to ensure that you have the best possible experience with our products and to support you in any technical challenges you may encounter.
Hi, On receipt of new Amflow bike i followed the "Quick Start Guide" to assemble the bike, however I am having a problem getting the handlebars and stem "tight". That is when i tighten the stem bolts (section 2-b) using the required torque figure it is still possible to rotate the handlebars with respect to the front wheel. I dont want to overtighten these bolts so would appreciate any ideas on how to resolve this issue. Thanks
Dear customer, the torque value for tightening the stem should be between 5-8 Nm. Could you please confirm if you have used 5 Nm? We recommend trying 8 Nm to see if that resolves the issue. If you still experience problems with tightening at 8 Nm, please contact the store where you purchased the bike for further assistance.
thanks for the reply. Yes ive tried 8nm. Quite stiff but still possible to turn the handlebars. (Bike was purchased direct from Amflow on line).
Hi Amflow team,
I want to change the standard derailleur on my Amflow PL Carbon to a SRAM AXS derailleur. How can I connect the SRAM AXS derailleur to the motor/battery? Is the SRAM AXS Extension Cord for Eagle Powertrain compatible? Or do I need a special cable? (and how to get it?)
Thanks from Germany,
Peter
I see you publish 'standover' height for your bikes but for any bike with a dropper post, the 'sitover' height (the lowest height of the top of the saddle above ground) is just as important .
What are the 'sitover heights of the Medium and large frames?
Hi Amflow team,
Peter
Yes it fits. I assebled myself. There is a port free at the Drive Unit.
Hi. Could you, please, put a picture of the cable conection? I would like to know if the motor of my ebike is compatible with the sram axs cable.
Thank you.
Hi Amflow team,
Peter
Hi there, we understand that you need to purchase the required power cable. This power cable is provided by SRAM and is not a custom design by Amflow. You can purchase this cable directly from SRAM, and the material number is 11.3018.028.003. If you have further questions, please send an email to [email protected] or use our chat service on our website :)
Best regards
Amflow support team.
Hi billium, the medium size is 775.5 and the large size is 795.5 😊
Is there any chance to plug in the AXS derailleur cable without disassembling the motor???
EDIT:
Ok, find a solution - if you disassemble the two motor screws marked red the motor slides out at the front and you can reach the cable :)
Hi Amflow. Does the Avinox system have accelerometers (movement sensors). Could the system record jumps like Specialized and Garmin?
Gordon
Good to have you here,looking at purchasing in the not too distant future,but i have niggles!
why is there no rubber gasket between the screen in frame and frame?
i could possibly see water ingress,wire shaking loose.
i have seen lots of rider videos,and it looks like water ingress in cable grommets,no rubber gasket behind screen to frame,and……….. paint quality,should it be a given upon purchasing a new bike to invisiframe it,or should it?
iam seriously looking at the 800 pro atm.
thoughts?
Gordon
Hi Gordon, Currently, our system does not provide jump data recording for customer viewing like Specialized and Garmin. However, we appreciate your suggestion and will certainly pass it along to our development team for consideration in future updates :)
  • Like
Reactions: pmc
thoughts?
Hi Mister cube, we appreciate your interest in the Pro version! Our bikes are designed with an IP56 waterproof rating. The body also features drainage holes to effectively manage any water that might enter. While there isn't a rubber gasket between the screen and frame, the design minimizes the risk of water ingress. Additionally, the wiring harness is secured with cable guide to prevent excessive internal movement.
Regarding the decision to apply a protective film, such as Invisiframe, is entirely up to you and can depend on your riding habits and conditions. Our Amflow PL models do not come with a protective film pre-applied. If you choose to apply one, please follow the instructions in the Amflow PL user manual or consult with a store professional to avoid any potential damage during installation.
If you have any further questions or encounter any issues after your purchase, please feel free to contact us at any time. We are here to help and ensure you have the best experience with your new bike. Thank you for considering Amflow :)
thoughts?
Every frame I have ever had leaks water into the frame, even the e-bikes, everything inside the frame is waterproofed from the factory.
  • Like
Reactions: iXi
Good to know.
So for someone like me with short legs (29" inseam) and assuming 20% sag (=30mm), the medium with post all the way down will sit at 745mm = 29" which means I can sit with both feet on the ground once shoes are figured in.
Hey @Amflow_Support what diameter in mm is the 29in wheel set at in the amflow system. I installed a garmin speed sensor and set the diameter to 2300mm and the amflow is still reporting more distance covered than the speed sensor.
    668K
