Thanks very much for that offer @Tooks. I have just sat down to read through new posts on here after refitting the old valve!Steve, you don’t live all that far from me I don’t think? Feel free to pop down and I’ll get my compressor on it.![]()
F7ck me, that is horrible!Serviced my dropper. New bushes & seals & a very good clean out. I thought I'd taken a few pictures but apparently not. Nevertheless, here's the state of the old upper bush that sits behind the collar seal. Well overdue imo.
Nonsense! It will polish out!F7ck me, that is horrible!![]()
yes I understand that and certainly your last point about grease on the steerer is a common thing overlooked. What i was referring to was the top cap appearing to apply the correct tension when set but settling even before the stem bolts are torqued. I also do not tighten the top cap according to a torque setting but rather tighten until all play is eliminated, whilst there is no binding of the steerer allowing the forks to move freely side to side. With freshly greased bearings there is bound to be play after a short while as excess grease is ejected so some additional tension on the top cap bolt is a useful way to avoid that before then setting it at its optimal tension level.The top cap and bolt is only there to preload the stem/top and bottom bearings, the stem pinch bolts provide the security to stop it all shifting.
Make sure that the top cap isn’t hitting the top of the fork steerer and make sure you’re torquing your stem bolts correctly and there isn’t a glut of grease on the steerer/stem.
irie said:The question is does a Muc-Off Big Valve let through more air than a Presta valve with the core removed?
What are the minimum ID's of both valves?Yes, I would say so
A metric drill bit set maybe?I don't have anything I can measure the ID with I'm afraid
WTF…I’ve never seen a measuring tape like that before. HOW?I just popped out to the garage to compare the bore sizes of a Presta tubeless valve (with the core removed) and the MucOff Hybrid tubeless valve. The hybrid MucOff has one end suitable for the rim drilled for a Presta, but has the pump fittings for a Schrader, so it's not the largest bore size they offer. Can you tell which is which?
As far as I can tell, they are exactly the same.
To compare, I put a straight edge of paper on the screen and marked the diameter of one valve and then compared with the other valve.
Not sure whether you are winding me up, but I will respond as though you are not.WTF…I’ve never seen a measuring tape like that before. HOW?
Were you having a "senior moment" @Stihldog ?I thought I’ve never seen a tape measure like that before, but I stand corrected.
Nah, I think I wound myself up. I’ve never used metric for measuring wood before. I couldn’t get past the 3/3 digits.Not sure whether you are winding me up, but I will respond as though you are not.
It is a perfectly standard steel tape measure, inches and feet on the top and millimetres and metres on the bottom. They can be bought quite cheaply all over the UK and have done for many decades. I am astonished that you have never seen one before!
I've had at least one ever since I left home. This is a popular one for home use.
Stanley Powerlock Classic 3m 0-33-522 | Tape Measures | The Tape Store
Stanley Powerlock Classic 3m - The famous 3m (metric only) pocket tape from Stanley. Decades of quality and reliability, Mylar coated for 10 x blade life, Classwww.thetapestore.co.uk
My grandson's tape measure that he uses for work, is double sided, has a magnetic idiot end so it will stick to steelwork, scaffolding etc and measures up to 20m. In addition to powerlock (locked in an open position), it has automatic retraction (most do) but with a soft close end so that it doesn't take your eye out. Quite a bit more expensive!
It's the futureNah, I think I wound myself up. I’ve never used metric for measuring wood before. I couldn’t get past the 3/3 digits.
Whoa, I better eat something.
It does make sense and I wish our southern neighbor had changed over to metric also. It is definitely beneficial in most of the trades but I still need to carry both imperial and metric tools. Doubles the “fun” and cost.It's the future![]()
33cm = 13"Nah, I think I wound myself up. I’ve never used metric for measuring wood before. I couldn’t get past the 3/3 digits.
More than a few years ago now I went to the woodyard in my nearest town. I asked for some planed "two by one" (2" x 1" planed timber). He told me that "we no longer stock 2x1 as we have gone metric", the nearest I can give you is 50x25 mm. (1.968" x 0.984"), that OK? Seeing as planed timber was only ever to the nearest 1/16", if you were lucky, I said "OK I'll have that instead"..............
But I’m stuck with the imperial system for wood products. It’s kinda like learning a new language. It can be awkward and embarrassing when speaking to our EU friends.
Metric is OK for very small amounts measured in mm but above 25mm inches work better. Sometimes used to shop with my French then mother-in-law and she would ask for "un livre" of this and that (Maine-et-Loire).More than a few years ago now I went to the woodyard in my nearest town. I asked for some planed "two by one" (2" x 1" planed timber). He told me that "we no longer stock 2x1 as we have gone metric", the nearest I can give you is 50x25 mm. (1.968" x 0.984"), that OK? Seeing as planed timber was only ever to the nearest 1/16", if you were lucky, I said "OK I'll have that instead".
He then told me "It comes in eight-foot lengths, that OK?"![]()
"Un livre" is about one pound in weight. It is not surprising, because the old imperial system (and what existed in France before Napoleon's imposition of the metric system, was based upon human scale measurements.Metric is OK for very small amounts measured in mm but above 25mm inches work better. Sometimes used to shop with my French then mother-in-law and she would ask for "un livre" of this and that (Maine-et-Loire).
