Lights for my Turbo Levo - Lupine SL Brose Installation
Hello,
does anybody know how many Volts/Amps are on Turbo Levo 2018 light jacks?
Update: I tried to measure it using multimeter but both ports (head and rear light) did not have any power, any idea why (the battery was on)?
Hi,
Not sure if you speak German (or can use Google translator) but this link should help you further:
NEUE BATTERIE FIRMWARE X.23 MY16-MY18 LEVO / KENEVO
Thank you, Maastricht.
I am seeing something about hex to dec conversion in this update. I'm afraid it could potentially kill the speed limit hack. Can anyone confirm if the hack is still working after this update?
I can buy a flashlight but I cannot buy more speed :(
As I understand you are riding a 2018 model. In that case speed limit will still be possible also with the latest x.23 firmware. Only the 2019 Levo model with the new top tube display firmware 2.025 and newer speed limit hack is not working anymore. (at least via the BLEvo app)
Thanks. I'm using LightBlue hack. Are you saying that Blevo app can also hack it, is this the "newer"?
Edit: Nevermind, I found out that the FW update is made only by the dealer so I'm stuck for now.
Yes, BLEvo can do it too and BLEvo offers many other features too. Check out the BLEvo thread for more information or watch this video:
Hi there not sure if this is the right thread I'm having trouble sourcing the specialized motor switch for the Handlebar (I have a late 2016 levo) is there a third party switch I can fit?
Is there a cable available for the 2019 levo and if so what voltage does it give out?
I also have a 2016 Levo FSR. I was able to get the handlebar switch and cable from my LBS for about US$80. They are also often on eBay.
You will need a firmware update before it will work, but it is a huge upgrade.
Hi, coming into this thread. I bought a Lupine cable but a Chinese light (the one this person recommends: ). Question: does anyone know what light switch - preferably handlebar mounted - I can buy, the can connect the lupine cable and the light? Otherwise light will turn on every time I turn on bike.
Thanks!
The Supernova looks smart but seems a whole lot of hassle compared to my Exposure MaxxD. Ive got 8 times the lumens, self contained battery and no dodgy connections to let water in the motor, not much in the price either.
    673K
