From a distance if you squint, and don't actually look at the details. And ignore the poodle inner tube hybrid.It looks like AI is getting much better at generating bikes.![]()
Zoom in on the face and it looks like Rob Hancill…..the rider, not the poodle.From a distance if you squint, and don't actually look at the details. And ignore the poodle inner tube hybrid.
Last time I watched Rob on YT he had a left eye and teeth.Zoom in on the face and it looks like Rob Hancill…..the rider, not the poodle.
He’s been in a fight!Last time I watched Rob on YT he had a left eye and teeth.![]()
Youtuber meets Twotuber on trail ??He’s been in a fight!
I’m gonna wait for the free version …the pay-per-view version is just too much $$Youtuber meets Twotuber on trail ??
Question 2.5Before i drill a second valve hole , has anyone used 2 tubes in the rear tyre/tire? im thinking 2 light weight tubes which will be lighter than a heavy duty tube filled with sealant , i am a cheap arse so it will be a cheap thing to do . Not really sure about the pressures eg 2x10psi=20psi or 2x20psi=20psi????
No , you can buy them, the thick tubes with green sealant in them , i think they are called "thorn proof tubes" Repco brand..Question 2.5
You put sealant in the tube?Why?
Comment to Answer to Question 2.6No , you can buy them, the thick tubes with green sealant in them , i think they are called "thorn proof tubes" Repco brand..
In the UK we say belt and braces. For men of a certain age here… suspenders means something completely different.Comment to Answer to Question 2.6
Slime Tube?! Sounds like „with belt and suspenders“, as we say in Germany, and now you want to replace suspenders by another belt.
Question 2.7
How many puntctures have you had in, lets say, a month?
Subquestion 2.7.1
What was the main cause?
Pinch flats on rocks, could be one a week to one every few months , other advantages are less rolling resistance , less ballooning of the tube/tubes , more balanced wheel , in the event of puncture one tube hold air, low cost etc etc. No more sub questions.....Comment to Answer to Question 2.6
Question 2.7
Subquestion 2.7.1
I understood innertubes increase rolling resistance so adding more rubber would increase this?Pinch flats on rocks, could be one a week to one every few months , other advantages are less rolling resistance , less ballooning of the tube/tubes , more balanced wheel , in the event of puncture one tube hold air, low cost etc etc. No more sub questions.....
You might want to reconsider your expectations in interacting with this imho valuable forum if you are not satisfied with the information available from its given content in multiple articles / postings and individual advice received from its international members.
I don’t want to be pigeonholed into the category of genius …but pearls may be the answer (or ball-bearings). If a number of those were placed inside a tubeless tire, along with your favourite sealant, coagulation of sealant may not occur.… Every day I eagerly await his pearls of wisdom.
Now you are just being silly!I don’t want to be pigeonholed into the category of genius …but pearls may be the answer (or ball-bearings). If a number of those were placed inside a tubeless tire, along with your favourite sealant, coagulation of sealant may not occur.
The constant smashing of round objects inside a tubeless tire would prevent, or at least lessen, the balling-up of sealant and thus extending the use of your tire. As long as evaporation doesn’t occur, any puncture could be quickly sealed by the liquid.
I don’t want to step on the toes of a two or three tube theory …but my carbon rims could survive.![]()
Yeah!Now you are just being silly!
Surely ping pong balls would be a better choice?Now you are just being silly!
Did anyone try construction foam? Does it make sense to use in tube instead of tubeless and full fill at home and never ever be afraid of punctures again or to go for quick on trail repair?
Hang on a mo, didn't I read somewhere that there was a simple solution to all those issues?Pinch flats on rocks, could be one a week to one every few months , other advantages are less rolling resistance , less ballooning of the tube/tubes , more balanced wheel , in the event of puncture one tube hold air, low cost etc etc. No more sub questions.....
Since you are a Tasmanian i will answer you , I honestly did not think it needed photographic proof , most people[including Tasmanians] have seen a valve sticking thru a rim[think double vision after hitting that low branch], and its literally a 5 min job, take tyre off,drill, put tyre, tubes in [as normal], pump, job done.[also , my phone has like a 1 megapixel camera , wont see any detail]@ari I think this will settle a few sceptics if you can do this...
A photo of your rim with two holes in it and a photo of the tyre showing the two tubes inside. I will make your case a lot more plausible.
no, it’s still half inflated.Did this thread go flat ?
