Bike / Product Year: 2025
Manufacturer: Specialized
Model: Kenevo SL 2 Turbo Comp Carbon S4 Burnt Gold
Size S4 large
Asking Price: 3349
Location Belbroughton, Worcestershire
Description 2025 model warranty till 04/27 upgraded from factory spec. see specification below & photos.
Un-ridden since Oct '25 & selling due to injury.
Eats up terrain & in my opinion the best descending & climbing ebike out there today, providing an immediate skill upgrade with confidence inspiring, composed handling & bottomless travel. Super stable in the air, with 29" wheels it eats gnarly terrain, such a shame these are being dis-continued as its so light, it handles like an analogue machine compared to the sluggish full powered heavy ebike rivals on the market.
Updated SL1.2 motor kicks out 50Nm more than powerful enough, as this is a super light at 20Kg.
Invisiframed from new some wear marks see photos.
Rebuilt in '25 with parts from a '21 KSL, then rode for 6 months, but have just stripped & rebuilt with the original parts, hence most are new/unused or upgraded.
Setup tubeless, with orange seal, so no issues with punctures & less rotational weight.
Pedals not included.
Comes with charger & owners manuals in original zip up storage case.
Rockguards carbon bash guard.
See screen grab from app battery 100% health, mileage close to 1k but mostly uplift.
Available to arrange viewing in advance for postcode in Belbroughton , bank transfer to clear before bike leaves. (bike doesn't live there, but if you buy i will provide my address)
Message if you have questions,
Frame FACT 11m full carbon, 29, full internal cable routing, 148mm spacing, fully sealed cartridge bearings, 170mm rear travel, geo adjust head tube, geo adjust horst pivot (Burnt Gold metallic colour)
Fork (NEW) RockShox Zeb Select, Charger RC damper, 15x110mm, 44mm offset, 170mm of travel
Rear shock UPGRADED to Fox X2 Factory Kashima (was Rockshox)
Motor Specialized 1.2 SL Custom Rx Trail Tuned Motor
Battery Specialized SL1-320, fully integrated, 320Wh
Charger Custom charger, 48V System w/ SL system charger plug
UI Remote Specialized MasterMind TCU, percentage of remaining charge, 120 possible display configurations, MicroTune assist adjustment, over-the-air updates, ANT+/Bluetooth®, w/Handlebar remote
Wiring Harness Custom Specialized wiring harness
Crankset SRAM Alloy crankset, S2/S3: 165mm, S4/S5: 170mm
Pedals PEDALS NOT INCLUDED IN SALE
Chain SRAM GX Eagle Transmission Flattop Chain
Cassette (UPGRADED) SRAM XS-1270 TO->75 (LIGHTER) Transmission Cassette, 12spd, 10-52t
Shift Levers SRAM EC AXS POD RGHT DISCRETE CLAMP D1
Rear Derailleur SRAM S1000 Eagle Transmission Derailleur
Front Brake SRAM Maven Bronze, 220mm rotor
Rear Brake SRAM Maven Bronze, 200mm rotor
Rims UPGRADED TO ROVAL TRAVERSE, FRONT NEW (Factory is normally Specialized 29, hookless alloy, 30mm inner width, tubeless ready )
Front Tyre (NEW) Butcher, GRID GRAVITY casing, GRIPTON® T9 compound, 2Bliss Ready, 29x2.3
Rear Tyre (USED ONCE) Butcher, GRID GRAVITY casing, GRIPTON® T9 compound, 2Bliss Ready, 29x2.3
Handlebars (NEW) Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 30mm rise, 800mm width
Grips (NEW) Specialized Trail Grips
Saddle (NEW) Bridge Comp, Hollow Cr-mo rails, 155/143mm
Seat Post (NEW) X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SLR LE lever, 34.9mm, S2: 125mm, S3/S4: 150mm, S5: 170mm
Seat Binder Alloy, 38.6mm
Inner Tubes (TUBELESS WITH ORANGE SEAL) NOT Specialized Turbo Tube 29X1.75-2.4
Chain Rings SRAM T-type ring, 32t
Front Hub (NEW UPGRADED DT SWISS 350) Factory is normally Specialized alloy front hub disc, sealed cardridge bearings, 6-bolt, 15x110mm thru-axle, 32h
Rear Hub (UPGRADED DT SWISS 350)
Alloy, sealed cartridge bearings, 12x148mm thru-axle, 32h
Spokes Sapim D-Light J-Bend (Instead of DT Swiss Industry )
Stem (NEW) Alloy Trail Stem, 35mm bar bore
Swat SWAT CC, integrated tool and chain tool with spare link in steerer tube
