Important safety note from Canyon: the Spectral:ON CF / CFR and Torque:ON CF models may have damage to the battery
Arminius
EMTB Pro
Rhein-Ruhr Delta, Germany
Full notice - Mandatory battery check and safety notice
Extract:
„Understanding the issue
The batteries used for our E-bikes are sourced from reputable companies and tested to meet or exceed industry standards. We have been notified that a small number of batteries may be liable to damage the housing appearing as small cracks, gaps or similar.
In rare circumstances, this could allow moisture inside the battery, potentially triggering a short-circuit that bypasses the fail-safe protection mechanisms. Whilst extremely unlikely, we cannot rule out that a damaged battery might catch on fire, resulting in a risk of personal injury or damage to property.
We must instruct you to please stop using any of the affected batteries in your bike and to not charge them.
Don't forgot to include the 'Do not use at all and wait for at least 4 weeks for an update' bit.
I am off work for a week purely to get some good rides in, I have 4 rides planned starting with Brecon Beacons tomorrow, then this lands!? Devastating isn't in it, especially when on my 2nd battery as my original is one of the ones pictured, it's replacement also on the list of do not use.
Have always thought Canyon's customer service has been really good so I hope this resolved in a more timely manner than what is currently being indicated. Fuming isn't in it.
Hoping they are quicker than 4 weeks, im effected, and 4 buddies with a CF8s and a CFR. My bike has been shutting off randomly since I bought it. Shimano replaced the wiring harness once, and they replaced the EP801 motor. Its probably been the battery the whole time. After they replace something it works great for a few days, thern back to shuttig down on rides. Other then that, the bike is awesome. I keep getting trophies on strava in the endurance capitol of the world.
Thats what it may look like, copied from Torque:ON-Spectral:ON my22/23 Gerissne Akkugehäuse
This is what they're talking about :
There's plenty of discussion about it on the FB groups such as :
For discussion, this was my reply to one of the threads which is relevant :-
"To be fair, and only addressing part of your thread, Shimano motors are decent, especially with the new firmware. These batteries are made under licence from Shimano under the STEPS program so the blame can't be entirely laid at Shimano's feet - especially if these batteries passed initial testing and due-diligence. Problems subsequently occuring is clearly unexpected for them but indicates a lack of product testing, clearly.
I'd be more than happy to have a Shimano powered e-bike again without hesitation however - but with a proprietory Shimano battery, not one built under licence unless it was tried and tested over a number of years, demonstrably so.
For me, the real question is what they're going to do about it, or rather, what they can do about it.
These batteries are manufactured by Trendpower (formerly Simplo) who are a HUGE battery manufacturer and they are made in batches based upon a minimum order from Canyon (I know all this after a 2 hour phone call in August with the head of Canyon Sales UK) of (I forget whether it was 100 or 200 units) basically it is a container load but the max number is quite limited due to shipping safety constraints.
There are tens of thousands of Spectral:ON's out there across the globe with these batteries so what can they possibly do about it without incurring crippling and possibly bankrupting costs.
Based upon what I know from inside industry information, the 900Wh batteries cost Canyon UK around £200 - £300 by the time they land in their London warehouse and obviously a portion of that is shipping and handling costs but even so, let's say they cost Canyon £200 each (retailing at £1100), and let's say they've sold 10,000 bikes, that's a ball park figure of £2million to replace, plus shipping to each customer which in the UK is around £60-£90 due to the Lithium battery shipping issues (a lot of couriers won't touch them now, the larger ones over a certain weight).
I also have a battery and I would think that 4 weeks is a VERY optimistic estimate if the solution is a new battery given sourcing leadtimes and 2 weeks of boat shipment from Asia. I assume that Trendpower will be footing the bill as it is likely due to there process control. It looks like most failures are at the screw boss and I would guess it is due to issues with control of a ultrasonic insertion process.
Nope. Weak plastic, the cases are cracking in all different areas. What you noticed is just a weak spot. Cracking has been going on for a long time, and can be found on all areas of the case. The german forums have a thread going back to early spring on this problem
I think they're saying that they will have a response within 4 weeks, not a solution.
This is just bad design in the first place, so as it reach also now some potential health issue they have no choice to stop even before having any solutions.
Could be a simple battery replacement but that would require total new design/batch (could be already in the process of it as nothing is new here), this could take long.
I do not see any other alternative honestly, one would be a new frame and new kind of battery but who knows if the new version would use shimano motor too? This would in any case be way too expensive for them.
Maybe stress fractures from heat expansion?
I'm in the same boat. However having only owned the bike (ONCF9) since July24, my battery casing is in perfect condition. So I'm tempted to still ride!
Anyone else have the same thoughts!?
If my CF8 battery has no cracks, I will be riding. Unfortunately my bike is in the shop so I can not inspect.
A properly designed and manufactured plastic housing can be extremely strong and durable. Process controls are critical to assure the strength is not compromised. Processes such as drying the resin, temperature and pressure are critical to assure the plastic maintains designed strength. Flow lines during molding cause weak areas. Improper boss insertion could cause excess stress. During ultrasonic insertion the plastic is melted during insertion. If the plastic is not melted, the result is a boss crammed in and thus plastic is stressed. Different chemicals can also greatly weaken plastic.
Whatever the cause, replacement parts are some time out. I am glad I recently ordered a Rail 9.8 XT to have a "spare" bike.
Nope. Just brittle plastic that was to thin. Its all about saving production cost. Better plastic and a hair thicker will solve our issues. Design is not wrong. Material and craftsmanship is the problem.
100% on a side note, my spectral has had nothing but problems since I bought it, due to the battery. They replaced motor and wiring, and it still shuts off. I know the battery is overheating, because sometimes it takes 5 to 10 minutes for it to cool down before the bike will power back on. So just use some caution.
Specification of the plastic housing - material, shape, thickness etc - all part of the design process. Bad design whichever you spin it.
So what are they planning? Sending us out replacement batteries? I guess they can demand we send the old batteries back so the cells can be re-cased although I don't know the legalities of sending potentially spontaneously combusting giant batteries by post. Either way I'm going to inspect mine at the weekend and if I don't see any cracks I'm going to ride it. But boy of boy this is someone's expensive mistake.
Again there are not tons of issue here. For crack battery or damage I am afraid there is not lot to do, you could have to send them to a Shimano partner battery for a fix but they will only be able to work on cells/wire etc, not the case.
If they conclude that the battery are repairable, unlikely they will ask for sending it.
If it cannot, maybe a proof of deposit would be enough to get a new one.
Even if you do have nothing right now, it could occurs from now, and during a ride? or a charge at home. I would be really careful.
It might seem extreme but certainly not vs legal claim on damaging human :D
NB: Glad I did not jump on a torque few weeks ago for my wife ...
They have already stated that the batteries should be disposed of (good luck with that in the UK!) and after having a lengthy call with the head of Canyon sales UK in August, I can understand why - a lot of couriers now are refusing to carry lithium batteries OR are charging exhorbitantly for their services, they deem that the H&S risks and implications are too high.
So, they aren't going to repair them that's for sure. They 'may' send out replacements to wind down the existing stock but given their recent position statement, this would seem unlikely.
We can only wait and see but I and some others don't believe the UK will receive a response in the stated 4 weeks, it will probably be longer than that.
There are many cases of people continuing to ride with damaged (cracked) battery cases. The cells are wrapped inside the case so will be somewhat water resistant, they may even be sealed by that wrap and/or some sort of protective shock-proof insulation or other material. This would make sense as Lithium cells can react to air and moisture if damaged.
So, unless you have a severe impact or crash that causes direct damage to the battery casing (through the downtube) OR have water ingress sufficient for the lithium to come in contact with it, then you should be ok.
From Google :
Pure lithium is highly sensitive to air and moisture, and can spontaneously ignite. When exposed to air, lithium reacts with oxygen to form compounds like lithium superoxide, lithium peroxide, or lithia. Lithium also reacts with moisture to form lithium hydroxide, which can deteriorate the battery's electrochemical performance.
Nice to have another emtb to ride.
Are these battery really sensible when they are in good shape for any delivery?
I mean we good wait for solid battery (salt) or plutonium one (some CRC32 prototype exists lol) but unlikely for 2025 :D
wow..what a disaster!! No courrier is going accept a damaged battery so returning a battery or sending it for inspection etc other than doing that yourself will not be viable. Can these non Shimano batteries be changed for Shimano ones?
I've already covered all this in another thread so won't go into as much detail but they've not been accepting or requesting batteries to be returned for quite some time (years) due to the costs and H&S logistics, particularly in the UK and Ireland.
The 4 battery models in scope here are made by Trendpower (formerly SIMPLO) 'under license' from Shimano under their STEPS program but they are designed specifically for the Spectral:ON and Torque:ON.
Everything else is covered in this thread and my other thread from August regarding battery availability.
Yeah, there is no chance that someone will step up to build these battery with more success. They might be able to make them beefier but the form factor cannot change at all.
It is great that FB and forum covered this for month but I still feel the, call it pain, for all other who did known or buy too soon.
Like I said elsewhere "Deutsche Qualität" does not relate to new world new they only do assembly, even more when they f.. their design.
What is also pretty awful is that tons of people are saying that we deserve it by buying from a brand with so cheap/aggressive prices ...
    670K
