I have SRAM Transmission obviously including a flat top chain. So how are you guys checking chain wear??
I have read conflicting information and some that makes little sense to me!!
SRAM appear to recommend changing chain at 0.8% wear as tested with either a stupidly expensive SRAM chain checker or a Pedro chain checker, yet both appear no different from any other chain checker.
I have also read that mechs at SRAM training workshops have been told to just run both chain and cassette until gear change is no longer working well and then change both together.
The only difference between the flat tops and any other 12 speed chain as far as I can see is that whilst the pitch remains at 1/2 inch/12.5 mm, the rollers have a larger OD. The difference being 7.72mm as opposed to 7.65.........meaning the gap between rollers is 0.14mm smaller.
Currently I am using the same checker I have always used so I am assuming when it gets to 0.5% wear on the flat top chain using it, the wear is actually more than that.......but still well within 0.8%. ?
