As long as it's not aluminium based like some of the marine greases, you should be fine. However, just ensure it is good and tacky.
What don't you like about aluminum based greases?
If you can’t get specific pliers then a modified Cir-clip plier(s) will work. That’s what I did. There’s a number of pictures posted here (I have posted also) that could help.
I ground off the small pins and thinned out the tip slightly. You may need to sacrifice a tool, or part of a tool, but it works fine for removing that C-Clip.
Unfortunately, there is conflicting information for this out there, some manufacturers say it can and some say it can't. I have seen boat trailers where marine grease has been pumped into the hub bearings and the original lithium grease has run out as oil, causing bearing failure in 3 or 4 months. Therefore, I tend to err on the side of caution.What don't you like about aluminum based greases?
You can see where I am going with this,
Bearing man said is ideal!!!I picked up some Motorex 2000 grease just to see what it's like.
Damn, this stuff is sticky! I've not used a grease like it, it has an almost silicone feel to it and is hard to wash off.
Anyone using it on these seals? I feel like it would do a good job![]()
To bad the store here in Greece sent me the wrong one yesterday.
Exactly the same stuffWhat did they send you? I noticed there is a bike specific one but the only difference I could see is it comes in a smaller pot, has a brush and costs more
I got it in a cartridge, I assume it's the same stuff unless anyone know different?
No, we won't see one of these for a few months yet, but will post my thoughts when we see one.Off topic but have you got your hot little hands on a Gen 5 yet, BM? & if so whaddya think?
They ship the FETT 176 all purpose grease.....
"We are sorry for the inconvenience but we have only the small container with the brush at the moment.... "
No thanx. They took it b....
Maybe the waterproof Belray I have is good for the seals but won't risk it.
Bearing Man said 2000 is good so I go for it.
I have 7 motors to look after and another 3 in 20 days........
Can't play with chances.
One motor is already to the service because of error
Error to DriveUnit Voltage transformer....
Yes, I am a prolific Bosch Gen4 abuser.If you look at the snap in Stihldog’s post, on the tube of Bosch Grease it tells you what it is and quotes the grease specification.
If you look at page 2 of this thread I try to figure out what the specification codes mean. So you should be able to find greases in your country that suit from figuring out the codes and looking for similar spec greases.
Alternative Grease for servicing the CX seal.
But yes,obviously as Bearing Man says, if you can find some Motorex FETT 2000 or similar that looks much the same as the Bosch stuff. A tub of that should keep you going for many years.
Got a Motorex 2000 big box few weeks back after BearinMans suggestionIf you look at the snap in Stihldog’s post, on the tube of Bosch Grease it tells you what it is and quotes the grease specification.
Can I just ask, why don't you guys just use the Bosch grease?
Je ne sais pas si c'est par rapport à mon message.Je ne sais pas si c'est le meilleur ou le pire fil de discussion ici
C'est une excellente information, c'est sûr, mais cela vous fait vraiment penser « hmmmmm vraiment » en termes de la façon dont ces choses sont construites, d'autant plus que Bosch est considéré comme le MEILLEUR en matière de fiabilité, pas le pire.
A thing that has stayed with me on this subject is @Bearing Man pointing out that the vast majority of the ebike market is commuter bikes that are used almost exclusively on tarmac in the dry. Therefore, the motors work exactly as designed I.e. there's no financial incentive for the manufacturers to spend dollar on building them to take what mountain bikers put them through.I'm not sure if this is the best or worst thread on here
Great info for sure, but really does make you think "hmmmmm really" in terms of the way these things are built, especially as Bosch are considered the BEST at reliability, not the worst.
It's a valid point, but doesn't help 'us' here as we're primarily MTBs i think.A thing that has stayed with me on this subject is @Bearing Man pointing out that the vast majority of the ebike market is commuter bikes that are used almost exclusively on tarmac in the dry. Therefore, the motors work exactly as designed I.e. there's no financial incentive for the manufacturers to spend dollar on building them to take what mountain bikers put them through.
