How bad are Schwalbe Eddy Current tires to install?
I use the third pair of eddy current tires. yes, gravity is generally a problem with schwalbe tires, but it's nothing a person can't put on. I ride the rear eddy with a tanuss insert
Related to EC's sidewall protection in rocks, how well does the rear hold to cuts and slashes?
My Surly DWs 2.8s were a real b$tch to put on my 44mm carbon rim and a full-round Victtoria foam insert, sun heat up and soapy-foam-water barely helped, which I'm replacing with an EC2.8. Not looking forward to Hulking out, so I think I might try Schwalbe easy on lube.
Clocked over 1000 miles on my Eddie .
At least 200 on the road riding to and from my local trails
Soft compound still has loads of life left .😀
Any sidewall scraps from rocks that you've been able to endure?
All good , I do a very rocky 1000m run that strewn with sharp rocks that sliced a friends max maxxis rear tyre.
No marks or chunks taken out of mine.
I've got one of these NIB in the USA I'd sell for $55 shipped (48 state). It's the 27.5 x 2.6 version.
Hey there, has it been that long since we chatted?
I've happily been on a Relay since 2 April's ago, so 18 months now. Loving it!
I've followed your build here, came out real nice.
Eddy Current super gravity mounting technique, usually three clamps but have lost one
Interesting workaround. Does it have a closed cell foam insert too? And did you use any bead "lube" like...👇
No inset , no lube, went on ok, the 29 inch front that I did a few years ago was a pain ti get on but I have the super trail on the front now which was a lot easier.
I think the clamps may be a good idea. I use the older version Vittoria full inserts...👇
So, definitely adds to the difficulty seating the bead...that and the carbon rim sticks a bit more, so going lube too I think.
