You could drive a Corolla around the Nurburgring. There are more interesting vehicles to do that with though.
Arguably a Corolla would be a good choice for your first 25 laps of the ring
Horses for courses. But I'd notice the lack of torque when I was doing too much less than 20km/h up a reasonably steep hillI generally notice the lack of torque on my SL when trying to ride up stuff I wouldn’t attempt to ride up on a mtb.
Ah but would you fork out big money for a new Corolla and know you have to drive only it there for the next few years?Arguably a Corolla would be a good choice for your first 25 laps of the ring![]()
Also Rocky Mountain, 150kg.So seems 131kg is too heavy for 90% of emtb, seen couple which are close to combined weight, Santa Cruz heckler 157kg, mondraker level xr 150kg, cube stereo hybrid 160kg,hai bike all mountain 4/7 150kg, giant trance 157kg, think could risk on these Orbea and Trek seems to be max total 130kg
Thanks some good insights will take everything you’ve said here to wittle down in my head as to what I’m looking for, is there a reason for Bosch over say Shimano EP8 at 85nm? Looks like can add coils to existing suspension to give more resistance is that correct. ?Also Rocky Mountain, 150kg.
A couple of things on that:
- the longest travel bikes are generally built burlier. Also the longer travel takes more of the hit in the suspension. Go for a Enduro type bike if you want the strongest bike 160+ rear travel but lean towards more. I don't see a Levo being a contender. Something with a burly frame, 38mm stanchions, the heavy kit. Kenevo maybe but meh 27.5. Maybe a Focus Sam2 (lots for your money, built like a tank), or the Mondraker Level like you mentioned, and yes I'm biased but Rocky Mountain Powerplay would also be in the ballpark.
- I would say you most definitely want full powered, 700+ battery, and more is probably better if you're into big rides
- I'd recommend Bosch or Rocky Mountain. They are torquey. Bosch is super refined. I like the RM because I hate the Bosch clatter but a lot of people don't seem to mind it.
EDIT: A coil would make sense too for the rear shock. Not essential, but it's going to be a lot of pressure for a 130kg rider and only the highest end shocks are going to play well I think. One of the higher end coils would make sense and less maintenance over time (more hassle getting the spring right but once done it's done).
Hmm might be some personal preference creeping there I've never really liked the Shimano motors since I had an E8000, which was weak as piss. I've not had the EP8 but consensus seems to be it's weaker, certainly at lower cadences, and I very much expect that will be blindingly obvious riding one (versus Bosch or Rocky Mountain). I felt the same with the Brose, although that does not have the clutch clatter which is a big saving grace in my book. On Robs' youtube channel and others there are motor comparisons with unscientific but good-enough-for-me hill climbs, check those out.Thanks some good insights will take everything you’ve said here to wittle down in my head as to what I’m looking for, is there a reason for Bosch over say Shimano EP8 at 85nm? Looks like can add coils to existing suspension to give more resistance is that correct. ?
cyclinic.com.au
Yeah of course they all work. They'll all get you up a hill with a load of bread for sure. Just depends what you're used to. I like to ride quick up as well as down and a stronger motor obviously does that better - especially for us heavier ppl. For me the stronger motors have all seemed to do much better in terms of range, which was one of OPs main requirements. The Brose had a lot less range than both the Bosch and the Dyname for me, it was quite noticeable, with a similar (quite high) level of support.My experience is somewhat different, the only Shimano motor I’ve ridden is the 8000, but it had enough poke to comfortably hold a wheelie up a fairly steep fire road in the Wye valley (and instantly made me want to buy the bike because it was a laugh). The current Brose motor is also plenty powerful and is the most natural feeling assist of the current full fats, I rode one for the baguette runs in the alps this summer and it easily had enough power to get back up the hill to the chalet with a load of bread under one arm. Not a terrible bike in the park either.
The E8000 though is pretty dated now, you might be feeling some nostalgia there I think![]()
If my Rocky got nicked, I would actually buy the another one. Not sure I've thought that about an ebike before. The only conundrum I'd have would be whether to spring for carbon high spec or not. I bought a alloy low spec and did it all up, I haven't brought myself to adding up how much that ended up beingBuying again it’ll probably be Bosch - I have no complaints with how the Levo rides, but everyone has a Levo and I just want a full fat for shuttling, so the Bosch punchiness appeals.
Interesting, what weight range are you in if you don't mind me asking.Tedster, this may be of interest to you.
I've just completed the Greater Ridgeway Trail, almost 400 miles over 8 days. Did it in two halves, the first half on a Gaint Reign e+1 in May with 625 battery and the second half on a Trance E+2 with 750 battery. The Trance was the better bike for me, the Reign was overkill.
The only mods were slightly higher bars, 2.35 Smart Sam tyres, a better seat, Grip Puppies and inner bar grips. The bike was right for me on this trip and it coped with everything well, some sections needed all the suspension (150/140) and others not, but I would not have wanted to be on a bike with much less travel.
The daily mileage was from 44 to 67 (Dorset is very hilly, Norfolk flat) but always had at least one bar left. I passed several gravel bikes along the way and the riders did not look that happy or comfortable to me, some said their hands were shaking after a few miles of gravel.
I usually ran the bikes in level 1 or 2 with the occasional level 3. With a lower power bike it would end up running near its maximum for longer so in theory the bigger motor should be less stressed and last longer.
I'm around 75kg, have lost a few this year with all the ebiking.Interesting, what weight range are you in if you don't mind me asking.
Mods sound like good shout, what are grip puppies?
Is this the standard Trance or the Trance Advanced, have you considered the range extender as well, or takes up valuable water bottle space?
Did you pop a rack on back or just wear small backpack?
![20240827_151208[1].jpg 20240827_151208[1].jpg](https://www.emtbforums.com/data/attachments/146/146119-2cc41d38125a2849f1875a0882bb4c95.jpg?hash=LMQdOBJaKE)
![20240829_112754[1].jpg 20240829_112754[1].jpg](https://www.emtbforums.com/data/attachments/146/146120-399ee499f9f04a4daa7a3ae493270c16.jpg?hash=OZ7kmfnwSk)
![20240830_173559[1].jpg 20240830_173559[1].jpg](https://www.emtbforums.com/data/attachments/146/146121-77f2e345f09cfb001f8467abba1ad8f6.jpg?hash=d_LjRfCc-w)
Looks good actually, wondering if advanced is worth extra moneyI'm around 75kg, have lost a few this year with all the ebiking.
Grip Puppies are foam over grips from the motorcycle world, I have them on both motorcycle and bicycles. The inner bar grips are really good too, they just give another riding position and handy in a headwind...all on ebay of course.
It's the standard Trance but with the 750 battery bought from here
GIANT TRANCE X E+ 2 750w Sapphire Blue 2022
<h2 class="lead headline">FASTER UP THE CLIMBS, LONGER LOOPS, MORE SINGLETRACK FUN ON ANY GIVEN DAY. FREE YOURSELF TO PUSH YOUR TRAIL RIDING TO THE NEXT LEVEL WITH THIS POWERFUL, FUN AND SMOOTH-RIDING E-BIKE.</h2><div id="keyperformancefactors"></div>www.rmcycles.co.uk
The blob on the top tube is a power bank as the phone would not last all day.
Re luggage, I am lucky in that her in doors was acting as support vehicle in our camper, so only needed to carry day stuff, just a seat bag and bum bag as I prefer not to have a rucksack. However the other week I did see a orange Giant emtb locally with a rack on the rear frame and bags on the front too...it can be done,View attachment 146234View attachment 146235View attachment 146236
Same battery Carbon Composite frame and live fork etcDoes the Advanced have the bigger battery?
Given some thought, I would feel more comfortable on a bike rated for a higher weight cracked a diverge and bianchi road bike 10kg ago, and at moment flipping between 3.
The Santa Cruz heckler looks great, 720w battery and weaker Ep8 motor, although new version coming out next month assume will use same battery & motor though. (157kg) -pros looks and higher weight tolerance, agile, cons - motor downhill apparently rattly and weaker, lower range
Giant Trance x e+1, apparently low front end not the prettiest bike but huge battery ok motor and can expand up to 1000w, be good for touring. (150kg) -pros distance covered cons- not great downhill and a beast
Cannondale mottera
carbon 1, 750w battery and Bosch motor the high end version (lab71)has the race motor but 7500 reduced from 12000 a bit outside my price range, alloy version has rack etc for touring and fair bit cheaper (150kg) - pro few versions to choose from and great motor or fantastic motor. Pros- great motor and decent battery
Honourable mentions probably ibis oso and Mondraker level r/xr seem much more Downhill focused but both great bikes don’t like Mondraker styling as much but does have spring suspension on some versions (150kg)
Rocky/trek/Orbea all seem to be rated to 130kg seems to be pretty much standard across e-bikes think be while before I’m down to 100kg again.
Leaning towards Cannondale because of motor, saw documentary on people touring with them in Italian mountains and seem reasonably agile and capable up hills, if could afford or see me for ~6k would get lab71 as non mullet version and lighter
Thanks for all your help with this really appreciatedJust one correction, the Rocky Altitude is rated 150kg. It's sitting next to me I can see the sticker from here
All good bikes, Cannondale sounds like it will suit what you're afterBosch is probably ideal for your use case too.
Mine's a A30 Coil, and at first I thought it must be a carbon vs alloy thing, but then in the manual here:Thanks for all your help with this really appreciated
New Rocky Mountain Altitude Powerplay Carbon 70 first ride review - this where getting from maybe different models have different max payloads, which model do you have?
Gonna wait couple more weeks, been reading up every day on bikes that take a bit of weight.Mine's a A30 Coil, and at first I thought it must be a carbon vs alloy thing, but then in the manual here:
on page 5 it says 150kg. The manual is for carbon and alloy. 120kg on that article seems wayyy too light, I'd be inclined to go with the Rocky manual.
I was just thinking about it this morning, everything on my bike has been upgraded except frame, motor and shell of the forks
EDIT: I was just thinking while out riding, if your intention is touring style riding and long rides with motor assistance on the lower side, then I would recommend the Bosch. I love the Rocky motor, I prefer it to the Bosch for my style of riding, but it will be agricultural for low assistance riding. The Bosch is very refined in low power modes by comparison and has really good Tour/Tour+ modes.
Thanks for the insights think going for cannondale eq, can take a rack and has good motor and range, gonna buy spare battery too, can get for £3,100 and will get 40% off with cycle to work, maybe replace wheels with dt Swiss or hope e-bike wheelsThat's interesting I hadn't realised the newer EP801 had overtaken the Bosch at lower cadences. I suppose there isn't a whole lot in it, certainly for a touring style of use, except for likely better range on the Bosch. The Bosch Smart System was a very refined system when I had it on the Rail.
Sounds like you got a good handle on things, let us know what you end up with!
But I believe, the first 4 names on your list are trying to achieve exactly that, as low weight as possible to minimize battery consumption, improve efficiency on climbing and be able to ride more XC miles.. maybe Trek is not 100% part of the list as it is more trail oriented...`
Have you thought of any of the light weight Ebikes with a range extender?
I don't think anyone makes an Electric XC bike as the benefit of an XC bike is that it climbs well due to light weight and short travel suspension. A motor kind of removes the restriction for climbing so you can have longer travel and the weight isn't as much of an issue. You can get a few good trail bikes though that aren't a heavy as the full powered bikes and feel a bit more playful.
Here's a few good options
Scott Lumen
Specialized Levo SL
Trek Fuel EXe
Orbea Rise
Focus JAM2 SL
Haibike Lyke CF
Santa Cruz Heckler SL
Pivot Shuttle SL
SIMPLON Rapcon PMAX TQ
The full powered Levo has a 700Wh battery and the bigger motor so that's most of the weight compared to something like say the Levo SL for instance, and I think the only difference between the Sworks and the other models is the lighter or higher end components. The frames are both FACT 11 Carbon fiber so there's no difference there. The Stumpjumper has a carbon shock link in the Sworks but the Levo specs doesn't mention this.But I believe, the first 4 names on your list are trying to achieve exactly that, as low weight as possible to minimize battery consumption, improve efficiency on climbing and be able to ride more XC miles.. maybe Trek is not 100% part of the list as it is more trail oriented...
I am in the same situation as OP.. after considering lightweight XC SL e-bikes (Rise and Ex-e) , now I am also contemplating 2022 S-works turbo Levo frameset mostly because it is sale in US for $3500. I know I can build it up top spec, from components on sale or what ever is already in my home... but the weight of 50lb for XC (longer exploration rides) does not sit right with me and also the mullet setup, would be first time for me... (I ride Stumpjumper and Epic, so I am confident in the geo is great).
BTW does anyone know if the bike would accept 29er rear wheel (perhaps with more XCish tire ) and how does it feel riding.
What is surprising me that the S-works with all carbon comps is so heavy... must be the motor and all of the internals in the frame and also the Sram electric components...
