Hello everyone. the bike is assembled, some other small things, then on to the real ride.
I did a firmware update. firmware
CRX30PC3615E102003.3 works for me. and with
CRX30PC3615E102003.2 it doesn't recognize my battery.
first impressions, the engine has a lot of power. only in B mode, after sudden pedaling, the engine shuts off, then starts again after a few meters. and when it rotates constantly, everything is ok, only when the pedal is pressed hard, the assistance turns off.
the weight is about 20.5 kg, I'm adding some other little things, so I hope it won't be heavier than 21 kg.
Frame XL
battery DIY 11s3p 21700 lg 5800mah cells.
fork Zeb 29 select 170mm
Shock suntour triair 210x55 with offset bushing. ete length with the offset bushing is 214mm, so I left the stroke 55mm.
Wheelset Mavic e-deemax mullet s30-s35
Tires prowall casing
front pirelli scorpion enduro s 29x2.4
rear in arrival pirelli scorpion enduro s 27.5x2.4
Cassette 12 spd. 11-52 aliexpress
Shifting Sram gx
brakes Hayes dominion a4, 220mm rotor
View attachment 137822 View attachment 137823 View attachment 137824 View attachment 137826 View attachment 137827
