How do you transport your Levo on Thule bike rack?
Kirlik_68
8
R
Hello ! I bought Thule Easyfold. I was happy until i tried to install my Turbo Levo 2022 on this bike rack... It is almost impossible. How you do it ?
I googled, then watched youtube videos and i put my Levo on the second place for second bike in Thule Easyfold6 but i cant fix my front wheel in straps... so help me please
The Hodge
Mystic Meg
3,703
7,522
North West Northumberland
I'm not familiar with that particular rack ..is it not possible to buy larger straps ?
Should all else fail buy some bungee elastic cord ..I 've used them on my bike rack previously ...
Kirlik_68
8
R
Straps are not the only problem. I dont know how to clamp frame into rack properly
Overkillit
39
21
Downingtown
I had a very similar issue with a bmw rack and ended up moving the straps further out on the platforms. I had to drill new holes for the bolts so if you aren't comfortable making modifications then longer straps will be needed. With the Alu frame, I would think that you could crank down the clamp plenty tight to keep the bike in place. I would just make sure to center the frame in the widest part of the clamp while tightening.
Snrbrtsn
205
159
Uk - Scotland
Not sure this shall help - I use thule Velo compact 3 bike carrier (also have 4th bike adapter)
I refer to A frame as the rear most upright where the clamp arms fit, I have these wrapped in tubing foam, both sides
I place my bike in the inner tray, rotate the cranks to level with the non drive side toward the front wheel
i locate the crank arm to the outside of the A frame and rest the bike on the A frame
using the smallest clamp arm, I place furthest left and clamp the Frame above the shock as fitted in picture above, then screw up loosely.
This Allows bike security
Note : On the velo compact the lower trays slide outwards as do the lights
I then locate wheel buckles and get 4/5 ratchet pulls
once secured, I check and tighten the clamp arms and lock
I often fit a securing elastic lashing belt tethered from the A frame and wrapped around bikes
If my son is coming, I place his bike ( Full suss non ebike) on the outermost tray, leaving thee middle tray empty.
If we take a friend, I use the fourth bike adaptor
Always only carrying 1 Ebike and either 1 or 2 non e-bikes
Sadly no pictures, though if I remember I shall take at the weekend
Polo1602
38
15
Cologne
BikeBert
81
469
Croatia
I have an older version of Thule EasyFold XT 2 with long straps and sadly it fits only one Levo ebike.
Perfect when I want to go biking alone.
However, if I need to take two Levo ebikes, I use another bike rack: Inter Pack Spider 2E.
Here's the comparison of those two bike racks:
Kirlik_68
8
R
Big thanks for reply! Is it possible to transport 2 bikes on Thule Easyfold?
Darkyhs
127
132
Freiburg, Germany
Can the Levo fit your Jimny without taking any wheels off?
BikeBert
81
469
Croatia
Due to specific frame shape and tube diameter in Levo there is no way I can fit two of them on this rack.
However, I can take 2 analog bikes on Thule EasyFold with no problem.
I don't think Levo can fit in Jimny's trunk even with two wheels off :)
It's really small car with even smaller trunk.
veryoldfart
68
72
Suffolk
we use a Thule XT rack to carry two Spesh Carbon Levos.
Thule make a specific adjustable bar designed to be fitted between seatpost and headtube, to avoid clamping around carbon frames. Costs abt £25 on Amazon. Then also fit 2 pairs of thule long straps and everything is easy peasy - plus no risk of damage to carbon frames
voila
donald.o
Zagreb, Croatia
View attachment 108112 View attachment 108113 View attachment 108114
Hi, I transport two Levos and a road bike on this rack (version for three bikes). I take batteries out to save weight. You need to fiddle s bit with three arms, but it’s doable without problems - and without rubbing on the frames. To fit tires, just deflate them a bit. Then I turn Levos one to left other to right - my XL is a bit longer so I adjust everything and then finally fasten all straps and arms.
Clarke
20
13
Bedfordshire
voila
Hi @veryoldfart would you mind sharing a picture of the adjustable bar, or a like to it? Many thanks.
Arminius
414
640
Rhein-Ruhr Delta, Germany
Hello & welcome,
I can‘t believe it and first thought the bike is to large for the rack. I changed to a new rack since the old one was not wide enough to safely hold the new 29er eMTB - for those there are not to many tow ball ike racks that are wide enough.
Having checked specs/dimensions of your rack on Thule website and finding your bike dimensions on Species website there should be no problem to fix it on the rack. 🤔
Not seeing the second tyre in your pictures I could imagine it is to close to the center of the rack what would not allow to correctly strap the second tyre as being pushed to far out of rack center. Hmmmmmm…….
BTW, the Thule Epos is expensive but the frame clamp/strap system is sweet.
Arminius
414
640
PS:
Regarding clamps some people replace the Thule ones by Ateras strap holders of the Strada:
Clarke
20
13
Bedfordshire
Looking forward to hear from this, I also have easyfold. Great rack, but only annoying thing about it are the clamps.
I tried to save some money by ordering with one of the “Used - Like New” options in Amazon for half the price but this monstrosity turned up 😂
I’ve sent this back and ordered it again at full price. If I don’t report back by the end of the week message me here again and it’ll send me a notification 👍
St4nley
160
328
Derbyshire
We have to transport 2 Levo’s on our easyfold xt and found these Fiamma bike holders to do the job, they are not lockable but we put separate locks on anyway.
525K
