Other Can we talk brakepads
ebikeZA
286
142
Cape Town
I need to replace my brake pads as they have been contaminated (hoping I can clean the rotors)
The choice here is rather limited so need to order rom across the pond. So if I am going to go to all that effort, what brake pads would you all recomend for my Codes.
Thinking metallic will give me better braking performance ?
And brand? Sram is twice the price of Galfer, Braking and others ... are they that much better?
6,161
4,686
I use these with SRAM RSC brakes. Low cost....no idea of postal charges to you though..company based in UK.
6,161
4,686
Lots of brands...........probably very few manufacturers and, most, if not all, will primarilly be suppliers to the automotive industry. Little surprise that all the brands offer very much the same pad compounds choices
Money Pit
40
26
This is true. It's very unlikely many bike brands are producing brake pads. A handful of factories will take orders from tens of bike brands and produce them something to meet a requirement and price point.
Said factories would keep their number of unique pad compounds minimal to keep costs down so chances are nearly every brand will be made from same stuff.
Just get cheapest that works imo.
Mcharza
E*POWAH BOSS
Aug 10, 2018
2,520
4,829
Helsinki, Finland
Galfers are made here in EU, actually in Spain. Long experience in cross and moto.
Rando_12345
199
267
France
Galfer purple or green, pretty much the best there is, but pricey.
Otherwise, if you know you will run codes for a while, buy a box of 3-4pairs of pads, if you can find them they work out much cheaper than individual pairs.
vertrkr
31
60
California
In the US many seem to like the MTX Gold pads, myself included and I'm 270 lbs. Almost no noise on steep downhills and good stopping power/modulation with crappy trek oem brakes with magura mdr rotors.
CarolinaCrawler
176
184
North Carolina
I have used Truckerco for years. They are cheap and work well. Resin is the quietest for me.
I've had great luck with Truckerco resin and semi metallic. I have struggled getting the sintered metallic brakes to bed in without glazing. Got some mt7 sintered pads and they worked fine, just a little grindy noise. Got some for some 8120 brakes and could not get them to work for anything. They are still in the drawer as spares.
RoJo
213
175
My favorite are the MTX Gold pads.
My favorite budget pads are the Discobrake Pro ceramics.
I get on really well with Disco Brakes Semi Metallic. Not overly powerful but consistent performance throughout and great value.
I tried their Kevlar pad a few times and honestly can't tell the difference. Curious about Ceramic Pro, have you compared these to semi metallic as I'm curious to know your opinions.
Natch
32
19
Oregon
The Ceramic Pros are the only Discobrakes I've tried. If you end up getting some please make sure to post your comparison of the two!
irie
2,038
1,990
Chichester, W.Sussex, UK
Front and rear Shimano D03S resin pads in Shimano M6120 calipers with Shimano M6100 levers and Swissstop 220mm Catalyst Pro rotors.
Silent single finger braking, no dramas. Sorry to be boring.
ebikeZA
286
142
Cape Town
Thank you for all the comments and advice.
I found some Galfer pads on bikein and ordered 4 sets of purple and 2 sets of black. Let’s hope they work well.
I’ll put another order in later for the 2.0 disk rotors. Is there a significant performance increase when going from the 1.8 centerline to the 2.0 galder (or even the 2.0 sram ones) >?
Mcharza
E*POWAH BOSS
Aug 10, 2018
2,520
4,829
Helsinki, Finland
Nice, put the purples rear and black std pads front.
The advantage that I have found in the thicker 2.0 mm rotors is that they do not heat up so easily.
And according to their recommendation, it should be changed when the rotor has worn to 1.5 mm
Rando_12345
199
267
France
Not sure about performance, but Galfer or HS2 thick rotors make codes feel a lot nicer by reducing the huge lever throw (i.e. amount of pull required before they engage), a bit of a pain to not have them rub all the time though...
CarolinaCrawler
176
184
North Carolina
I swear by thick rotors. I've started running Magura MDR-C rotors on all my bikes regardless of brake brand. They are nice, 2.3 mil rotors that are 25 bucks shipped to the house. I haven't had to true a rotor in a year.
ebikeZA
286
142
Cape Town
Are they not a nightmare to set up with that thickness and rubbing.
Ickle_legs
20
12
Sussex
I've been impressed with Gorilla brake pads 'Multi compound copper kevlar' in Guide REs(on full fat Levo) and Code R. Decent stopping power and much quieter in the wet than OE pads.
Have also bought Gorillas 'Ceramic with nano tech' but yet to try them out.
SwampNut
298
353
Peoria, AZ USA
Galfer or EBC metallics. Always more grip, better feel, better consistency in rain, but they might have a little squeak. Which is useful to warn hikers.
CarolinaCrawler
176
184
North Carolina
Its funny, the only brakes I've had an issue with rubbing are the Magura's they are designed to work with. I've got them on Sram and Shimano brakes currently and don't have an issue. I also have TRP brakes but they use their own 2.3 mil rotors.
Downhillr
222
106
SF Bay, California
Many of the folks I m our riding group have moved over to these MTX pads, particularly the Gold version. We ride a lot of steep, gnarly trail here in California’s SF Bay Area, and rain ir dry they exhibit good power, modulation and great fade resistance's…
525K
