Yup understood, sorry i have 2 issues. I have the speed issue which I am working with Jean on. However i cannot go into the setting to adjust motor peak power, acceleration, etc when connected over bluetooth, it keeps saying operation failed. If i am disconnected every once in a while it lets me go into the screen. Otherwise it just tells me to connect to device.
I found the app to be a bit flaky on the version of bluetooth used at both ends. If you have a version 3 245 then maybe use a different phone with a newer ANdroid and hence newer bluetooth. But is must be 5.0 or later.
Yah it is a 245 ver 3. My phone is a s22 with bt 5.2. Ill play around a bit more. Appreciate the help.
I have a pixel 6 with android 14 and Bluetooth 5.2 and have the same "operation failed" issue. Others have reported it as well. Hopefully Bafang fixes the issue soon.
@sandnap I see you are in herriman? Im just north of SLC by lagoon. You have a CEF50 as well?
Maybe it's the version of Go+ app itself.
The latest version is v2.2.0 Nov 2023. I suspect this is the version causing problems.
Maybe try previous versions 2.1.0 or 2.0.1
2.1.0 worked for me many months ago.
Thanks bro , it work for me now. I uninstall my V2.2 and install V2.1 . Can change the setting now.
I download and upload to my google drive below, also linda just send me new Update 48V firmware
Bafang – Google Drive
Thanks. very strange, the 4812 file i had, have not the same size than your ? mine in attached file, If an "geeks" want to see what is the differences
Close enough to fit my 3-pin charger plug? Replacing my dust cover for the 720Wh factory battery.
Possible replacement.👇
The dust cover looks more stout and then just splice wires to battery connector...🤔
OEM👇
FYI: I finally got Linda to physically disassemble the charging port to convince her that the dust cover was actually separate and therefore replaceable. Also that the covers likely could be sourced from their battery maker providing the charge port...(sorry frustrating but after 6 weeks of trying to communicate this to her, too close to the New Year's to inquire I guess?🤯).
Here's my charging plug 3 pin male.👇
Here's the 3-pin female replacement port. 👇 Is it close enough to fit? Any electrical engineers care to weigh in? (I don't know if the matching charger is 42 V/2.0 A for the replacement if needed. I'll try to find out if necessary.)
I think I'm going to pull the trigger on a CEF50. I want to know from a size perspective what folks have chosen. I'm a regular 186cm tall dude - 85kg. Whenever I check sizing charts I seem to fall between a L and a XL.
I currently ride a Rocky Mountain XL (This will be my donor bike) - it rides well although it can be a challenge to throw around.
The team at CEF50 suggested an XL - I'm keen to get some opinions from current CEF50 owners on this.
Cheers
Mike
Cheers
Mike
Cef50 feel a little small when u ride so size UP will be a good choice.
Cheers
Mike
I’m about the same height as you and I have the XL. I run it with a mullet and I can throw that around all day.
@mike_kelly any thoughts? Just buy it and see if it works?😵
The problem I see is that the plug I got and the one you originally got have a diamond shaped opening with two screw lugs that are glassed into the frame. Your new candidate is designed for a round opening, If you were doing this from scratch that might be fine but not when it is already cut-out for the diamond shape. The next problem with your candidate is that it appears to be designed for an installation that needs a thick "spacing" between where the nut screws on and where the outer surface contacts the frame.
Ok thanks. I'll explore your custom charging plug that you rigged for your battery extenders next.👊
It has turned out to be a good plug but it does stick out a lot and if you have narrow q cranks they could hit.
I forgot you are just using it for charging so it does not matter. It does have a nice screw-on cap.
Got a pic handy...forgot what it looks like.
Guys, regarding charger port, I'm thinking of building an extender for the summer but I was thinking of using a magnetic charging plug, there are tons on Aliexpress, some with a nice 90° angle and low profile. Have you tried this ? Also, not sure about Bafang default charger, there might be more than 2 wires, but you can find 3/4/5 pins connectors
    Join 43,206
