My latest iteration: Version 3 with Zeb buttercup up grade. Truly buttery.🧈👊
I thin I should do less than 18kg for my wife! But commuter bike, not enduro :)
My frame carbon has been upgraded to light weight and battery casing also carbon...
Nice! I don’t asked for the carbon casing, regular 480 48v.
But with a revelation which weights 1.8kg and a sidlux which is around 250gr, that should be light!
Ask Linda if they can make you a matching truck.
Wow! Look at that undercarriage lift purple bling! Shiny!😎
Personally, I would've just gone one simple purple Cobra stripe up the middle on the hood and just kept it matte black solid. 🤣
I would've kept my frame solid (really faded) but the violet skulls are light reflective when I ride at sunset and cross tarmack roads for better visibility... hopefully!🤞
The day I switched my revelation for the Zeb ultimate charger 3, I literally exploded my best time on my favorite track, kom on the Strava emtb segment 😁
Nice. I'm just trail riding but I was worried the buttercups were a little gimmicky for my riding style. My sense so far is that it they seem to add more suppleness over the RC2 damper/air spring!👊
Linda is back in office since today...
I asked her kindly to include a second guard to my order and she was fine with it. :)
Powered up mine for the first time tonight. I seem to have the wrong firmware, it says the speed limit is 15.5mph. Any others seen this? Also my go+ app doesnt seem to allow me to change any settings other than mph or kmh. Do i have the wrong app?
Also did you guys get grommets for where the main triangle exits and where the rear triangle enters? I just have 2 rectangle holes there with no grommets
2mm, too thin if you plan to hit rocks. Mine is just done to protect motor from stone projection. i have also interfaced a little peace of hard rubber. The rear part is 3D printed support.
Ugh, anyone serviced their bearings before? Im trying not to force the linkages apart but i am having a hard time separating them to check for grease in the bearings. I have had issues with chinese frames in the past with no grease in bearings.
