@goroncy - if I understand the information on the vendor site correctly, the VOLspeed needs to be activated each and every time when the bike is powered on. Can you confirm?
I agree, it’s a PITA to constantly turn the unit on every time the bike is turned off. It would be better if a code was used just to disengage it rather than the other way around. Retaining the settings even on power off would be way more convenient.Thx! I see the advantage behind it, but since I often have smaller breaks on my tours where the bike automatically switches off itself I find it a bit inconvenient for me. It would be cool if one could set the timeout in the Giant App ;-)
Are you still using the Volspeed and does it still work ok with the latest Yamaha Firmware with the Updates to the Power profiles ? Do you update the Firmware with the Volspeed in place or do you have to remove it ?Absolutely. The chip doesn't change a thing in the settings. Until you cast a spell (magic key combination) the chip just sits there and transmits the signal in unchanged form. When you switch it on all the tuning settings still apply. The only thing that was so so is that after I installed the chip all the settings were reverted to factory settings. 30 second later I had my settings back.
I am still using Vollspeed. I didn't upgrade giant's software for a long time now (a year?). One. There is no need. Two. Rumors were enough for me not to upgrade. I don't want to brick the bike. Everything works. And going above 25kmh is absolutely my priority. So updating the software now doesn't seem to make any sense.Are you still using the Volspeed and does it still work ok with the latest Yamaha Firmware with the Updates to the Power profiles ? Do you update the Firmware with the Volspeed in place or do you have to remove it ?
Have you ever tried a Garmin or Similar for the Speed display and setting the VOLSpeed speed ? I can try when i get my Tuning Box just curious.I am still using Vollspeed. I didn't upgrade giant's software for a long time now (a year?). One. There is no need. Two. Rumors were enough for me not to upgrade. I don't want to brick the bike. Everything works. And going above 25kmh is absolutely my priority. So updating the software now doesn't seem to make any sense.
Yep. I'm using Garmin edge and sometimes just the watch. When I press the special key combo to turn on the tuning chip maximum speed appears on the display to show that chip is on. Then you have couple of seconds to change the max speed. It's in the Vollspeed manual. Before switching on the chip your Garmin has to be connected with the bicycle.Have you ever tried a Garmin or Similar for the Speed display and setting the VOLSpeed speed ? I can try when i get my Tuning Box just curious.
Thank you That will help, I have read the manual talks about RideControl App but did not see other bluetooth devices mentioned. Thanks again.Yep. I'm using Garmin edge and sometimes just the watch. When I press the special key combo to turn on the tuning chip maximum speed appears on the display to show that chip is on. Then you have couple of seconds to change the max speed. It's in the Vollspeed manual. Before switching on the chip your Garmin has to be connected with the bicycle.
At least here you can see wich version is compatible and they are testing the new update Smart Gateway:V 20240329000E-Bike Tuning by bikespeed - bikespeed-RS
Make your e-bike faster - tune it to 50 km/h and beyond with bikespeed systems. Professional tuning available for Bosch, Brose, Yamaha, Panasonic, TQ, Pinion, and other brands.www.bikespeed.de
Hi there, Speedbox have recently launched their 3.3 Giant for Syncdrive Pro2 (85nm) and Sport (75nm). Feel free to send us a message in a few weeks/months to see how performance and reliability has been.Hi, has anyone found a working tuning unit for the latest software? I would like to update the software because i have problems with battery charging.
Has anyone had any experience with it? Does it work with the latest software update?Hi there, Speedbox have recently launched their 3.3 Giant for Syncdrive Pro2 (85nm) and Sport (75nm). Feel free to send us a message in a few weeks/months to see how performance and reliability has been.
I checked on www of both companies: speedbox and volspeed. Both say NOT to update the ebike's software and that both devices are not compatible with the newest software. I stopped updating and using ride control app before the made this recommendation so my chip still works. But the fact that they are not able to bypass the software for 2 years now is a big bummer. I would not buy this E-Bike without ability to tune it. 25kmh in EU is just not enough.Has anyone had any experience with it? Does it work with the latest software update?
