Swapping to an E7000 mode shifter
hemi.rokingi
82
37
Same combo I’m getting on mine when it comes.
I have the wolftooth on my Transition...excellent indeed
Hey Pybo, do you have the light action or standard version of the Wolftooth dropper? I found with the shirter standard lever that it would hit the bottom of the E6000 switch. Ended up with my switch on the right hand side - see pics above. Although not originally what i was planning, I’m very happy with this set up.
2unfit2ride
189
162
herts
Is anyone running a reverb X1 remote with the E7000? I'm keen to see the set up & know how it works for you.
Cheers.
Pybo
67
71
Middlesbrough
Mine was the Light action...the longer lever.
Getting the same set up again on new bike with the E6000 unit.
Hope it works ??
Gary
Old Tartan Bollocks
10,496
10,690
the internet
Cheers.
the E7000 controller is tiny it'll work fine mounted next to your grip so long as you have around a 16mm or more gap between your brake lever clamp and your lock-on collar. (assuming your X1 is mounted to your brake lever clamp).
