Cyctrac another M820 based EMTB?
mike_kelly
US
Products Description
Bike Model EM19
ConfRev M820+36V15A, HIGH
Frame Size 29(27.5)×16" / 18"
Bike Color Black / DarkGreen / DarkBlue , Full Holographic
Net Weight 20.9KG
Frame CYCTRAC, EM19, AM, High modulus Carbon fiber,Inner cables,Thru-axle12*148 Boost,140mm Travel, DNM rear shox200*55, UV laser decals
Handelbar Sets RS, Alu alloy,Matte,Handlebar 31.8×720,Stem 80, Clamps 34.9mm
Seat post KS adjustable lifting with hydraulic, Remote,31.6**395*125mm
Fork ROCKSHOX-RECON, Air susp,150mm,Manual,Thru-axle 15*110 Boost
Head Sets Alu alloy CNC with sealed Bearings 52*52mm
Derailleur Lever SHIMANO DEORE/M6100-12S
Rear Derailleur SHIMANO DEORE/M6100-12S
Cranksets Matching with Mid Motor, 34T
Cassettes SUNSHINE-12S,11-50T
Chain SUMC-12S
Brake RS-LD400, Alu alloy CNC, 4-piston hydraulic disc, with Ceramic heat sink, 203/203mm
Hub RS, Alu alloy,4-sealed Bearings,Slotted,Disc,32Holes,Thru-axle F15×110_R12×148mm Boost
Rim RS, Alu alloy with Double-wall&Rivets, W24×H19mm
Spoke SHUNJIU, Circular 14G
Tire MAXXIS, CROSSMARK, 29/27.5×2.25"
Grips Circular 22.2×120mm, PU leather&locking Ring
Saddle RS, Comfortable and Thickened for MTB
Pedals RS, Alu alloy CNC with Bearings for MTB
Motor System Bafang Mid, M820, 36V250W
Max Torque 75 N.m (Peak 95N.m)
Speed Limit 25KMh (max 45KMh)
Pedal Sensor Torque+Cadence
Battery Samsung 21700 Li-ion 540Wh, 36V15A
Endurance 110-130KM (pedal assist)
Charging Time 6-7 Hours
Charger 2A, DC2.1
HMI Bafang, LCD digital, 0-5 Modes
Waterproof IP X5
Max Load 150 KG
Seems expensive for the specs, but interesting too see !
I shutter to add up what I am spending on mine... :)
It is an aluminum frame too.
It's Carbon. This frame will be available end of June they said.
FrameCYCTRAC, EM19, AM, High modulus Carbon fiber,Inner cables,Thru-axle12*148 Boost,140mm Travel, DNM rear shox200*55, UV laser decals
Which one did you get?
Sorry for the late reply, I've been busy I put in about 45km so far and I'm enjoying it.
    Join 43,282
