Sold 2019 Trek Powerfly 5 FS Full Suspension: 3199
Larsey
25
34
MN
Bike Year: 2019
Manufacturer: Trek
Model: Powerfly 5 FS Full Suspension
Asking Price: 3199
Description: Available in Continental US for Local Pick-up or FedEx Ground
2019 Trek Powerfly FS 5 eBike
Pedal Assist
17.5”
Full Suspension
Bosch Performance CX
As New/Has not been on Trail
9 Total Miles on Odometer
Full Specs Below
Including the New for 2019 RIB (Removable Integrated Battery system) that allows water bottle placement
No Pedals
All Manuals and Charger
MSRP $4,799
$3,199
Available for pick-up in Baxter, MN or Continental US Shipping via FedEx Ground
Thanks for Looking!
Specs
Drive System: Bosch Performance CX
Display: Bosch Purion
Battery Type: Bosch PowerTube 500Wh
Max. Assisted Speed: 20 mph
Frame: Alpha Platinum Aluminum, ABP, EVO link, tapered head tube, Knock Block, internal derailleur & dropper post routing, Removable Integrated Battery (RIB), G2 Geometry, Boost148, 130mm travel
Fork: RockShox Recon RL, Solo Air, Motion Control damper, lockout, tapered steerer, Boost110, G2 Geometry w/51mm offset, 130mm travel
Headset: Knock Block Integrated, sealed cartridge bearing, 1-1/8-inch top, 1.5-inch bottom
Rear Shock: RockShox Deluxe RL, 205x50mm
Axles: Front: 15 x 110mm Rear: 12 x 148mm
Rims/Wheels: Bontrager Kovee 23, Tubeless Ready, 32-hole double-walled
Hubs: Front: Bontrager Boost 110 Rear: Bontrager sealed bearing alloy axle, Boost 148
Tires: Bontrager XR3, 27.5x2.35
Crankset: Race Face Affect Cinch
Chainrings: 15T w/Chainguard
Chain: KMC X10
Rear Derailleur: Shimano Deore M6000, Shadow Plus
Cassette/Rear Cogs: Shimano HG50, 11-42, 10 speed
Shifters: Shimano Deore M6000, 10 speed
Handlebars: Bontrager alloy, 31.8mm, 15mm rise, 750mm width
Grips: Bontrager XR Trail Comp, nylon lock-on
Stem: Bontrager Rhythm Comp, Knock Block, 31.8mm clamp, 0 degree x 60mm
Brakes: Shimano MT200 hydraulic disc
Pedals: N/A
Saddle: Bontrager Arvada
Seatpost: Bontrager alloy, 2-bolt head, 31.6mm, 12mm offset
