Looks like the bottom side of the stem.What is the bronze thing under the stem? Nice job on the cable routing.
hi. which items do you use to modified forks angle ? it's seem you have reduced the angle ? how beaves your bike in technical single track downhill ?I got tired of wiring so I drilled holes in the frame. I was able to change the head angle twice by combining head parts.
View attachment 130867 View attachment 130868 View attachment 130869
Thanks.
This is the old versionThanks.Is that the newest one, generation 3?
Yet, Linda disclosed they knew the first motor guard (Gen 1) was really weak...it broke with their pro rider when he was testing the frame. He recommended the protective armor guard be used to help mitigate the material flaws. But they still launched with the error anyway.FYI, Linda reached out to me proactively on the motor covers. I got to be honest with you. I’m really impressed with this company and this relationship we have as a group with them. it’s been a lot of fun to have a partner on a DYI project. @mike_kelly I mentioned you to Linda and she knows you by name, pretty great.
Finished my lightweight EMTB project, thanks for the inspiration from this thread.
Non-headset cable routing frame, and a little bit lightweight setup, whole bike weights 18.5KG.
It fit inside the CEF50 ?Here are the measurements that Bafang provides for the BT014 in their catalog.
A=470 B=52 C=63 for the 43v
YesIt fit inside the CEF50 ?
Thanks. that would mean that space availble is more than A=470 B=52 C=63, 54 X 65 ? I plan to insert battery whitout casing, only fixed upper and lower (alike i have done on the LCES1075), not verticaly along the diagonal tube.Yes
You should have the mounting plate for the frame to attach the battery.
The only thing I'll add is that you may want to use insolation foam, as the space between the interior of the downtube and the battery is roughly 20mm on all sides. Without the foam, you'll hear a rattle between the battery and cables within the downtube![]()
Have you guys seen this? Looks like the same company.
Full E-bike 29er Carbon Fibre Suspension Disc Brake Electric Power Assistance Bicycle Frame Mtb With Shim.ano Ep8 Mid M - Buy Bike Frame Bicycle,Frame Carbon Suspension,Custom Bicycle Frame Product on Alibaba.com
Full E-bike 29er Carbon Fibre Suspension Disc Brake Electric Power Assistance Bicycle Frame Mtb With Shim.ano Ep8 Mid M - Buy Bike Frame Bicycle,Frame Carbon Suspension,Custom Bicycle Frame Product on Alibaba.comx.alibaba.com
I love my Shimano motor, I would be down for one of these in a heartbeat. I’ve actually got a request for a quote into Linda.It is...
The interesting part is that it is made for Shimano EP8. I would still choose the M820 having owned both tho.
also they are now offering new custom batteries from ZS. The BT 480 (48v) and the BT 410 (43v) for the CEF50.
Let us know the result of the inquiry.I love my Shimano motor, I would be down for one of these in a heartbeat. I’ve actually got a request for a quote into Linda.
Is the EP8 a full 85Nm or the RS60? If the 85Nm I think I'd go with Shimano for more torque but lose the DIY repair...tradeoffs. Weight difference if full EP8 (2.7 kg) would be a minus (.882 lbs). but noise reduction on the ramp up for both Shimano is a plus. Although, the M820-75Nm (2.3 kg)is tolerable, be nice to have less whine.I love my Shimano motor, I would be down for one of these in a heartbeat. I’ve actually got a request for a quote into Linda.
Looks like the full EP8. 630Wh battery.Is the EP8 a full 85Nm or the RS60? If the 85Nm I think I'd go with Shimano for more torque but lose the DIY repair...tradeoffs. Weight difference if full EP8 (2.6 kg) would be a minus (.667 lbs). but noise reduction on the ramp up for both Shimano is a plus. Although, the M820-75Nm (2.3 lbs)is tolerable, be nice to have less whine.
Also, I noticed the frame has no extra power button hole in the top tube-bonus!![]()
EP801 Mid-Ship Drive Unit US for CEF52.Looks like the full EP8. 630Wh battery.I'd be interested in the future...but tapped out for awhile with the CEF50.
Plus, I could again overstroke it to 165 rear and 180 upfront for another 27.5+ x 3.0/2.8 build!
UPDATE: SZZS is checking on the battery size for the CEF52.My final analysis CEF50 V. CEF52: gain 10 Nm of torque but lose 90 Wh of battery juice and probably should buy a spare EP801 and spend an extra $800 plus an extender$?.
Cons:
gain 0.887 lbs
lose DIY serviceability, but buy another $800 buy spare motor
630 Wh battery, so lose 90 Wh and definitely need an extender or build a DIY 900-1000 Wh (maybe).
Pros:
Gain back full power 10 Nm. This is worth 2 cons IMHO.
BUT CEF50 wins it for now...it's a pound lighter and would cost less ($1k+?) due to range extender and spare motor.![]()
Looks they can use a 720 Wh as well for the CEF52.UPDATE: SZZS is checking on the battery size for the CEF52.
Currently no Shimano batteries are available, but should be able to make a bigger 720Wh battery for the +10 Nm of torque.
Salesperson is checking TBD...
Somebody should start a CEF52 thread today!Let us know the result of the inquiry.
