My Emtb life ( Ongoing Blog ): Current bike: Haibike Sduro Hardseven 2.5
I have PM'd and emailed Yes. no reply as yet but its only been a few days so will hold out on creating the new thread lol.
just read a similar issue was resolved with a new battery but im not convinced they had the same exact issue as it sounded more like the connector issue but if a battery has a damaged cell how does one find that out ? surely that would throw an error at least !
The battery holds and chargers like it always has, new sensor fitted and the side display / controller type A definitely doesn't have its own internal battery. Ive got my battery as tight in the downtube as it can be ( almost impossible now to budge ) so no random movements for disconnection.
Whats even stranger now is..... that once the initial cut out occurs it will also repeat even if im just coasting with no motor use at all lol.
such a shame as the only thing that's been bullet proof and reliable with this Haibike was the motor.
Hey Zimmer, You wanna buy a super light heavy weight ahead of its time tank ?
I have seen your e-mail and your PM. Sorry, but I struggle to answer messages over the weekends these days... need the rest at my age :sleep:
I was interested to watch your video (Day 3). When your motor stopped assisting, I could hear that it was still running, but had gone into "limp" mode, this then carried on until it looks like the motor switched off altogether? If this is exactly what happens at the end of your video, then it is a PCB fault.
Not sure if you do this or not, but the PW-ST has been fitted with anti tampering software, that sends the motor into limp mode. I don't think this is the issue with your motor, if it did cut out at the end of the ride, because they don't usually do this. However, the bad news is that so many people killed their motors with de-restrictors, that these PCB are currently unavailable from Japan. The other issue is that Yamaha are changing the software on all their new motors and PCB's to do the same!
We have been waiting 6 weeks for new PCB's so far, and finding one is not looking good... You maybe looking at buying a new motor?
Hi, Thanks for the reply.
So in the last part of that video i had just got the first cut out for that day. I was 3.1 miles into the ride and the motor and display cuts off ( no errors ) so the video section shows recording from directly after the initial cut out and the assist is reduced ( all modes feel like eco ) and within X time it will all cut out again, manually turn back on and same scenario repeats but no consistency in the time frame before it cuts out again ( it can be anywhere from 30 seconds to 2 minutes etc ) but always at a reduced assist, this can also be repeated whilst coasting down hill ( zero cadence on the motor ).
It has never had any derestricting attempts.
Does that sound more like the pcb issue ?
regards
regards
The motor can do a similar thing if it over heats. But, your pcb heat pads look good in your photographs and the issue does not seem to appear specifically during a climb, so I don't think it is actually overheating. However, the sensor on the PCB maybe telling the software, that the motor is hotter than it is? It still sounds like a PCB issue to me.
Thanks, really appreciate the info. looks like its a bike strip for sale parts, minus the motor .
Out of interest do you know of any other Yamaha motors that have the same mounting dimensions as the pw-st ? or uk pw-st supplier ?
Im gonna go buy you a coffee anyway now. Cheers bud
This time three weeks ago we could have just given you a new PCB and off you would have gone, happy... So sad!
Most Yamaha motors have the same bolt hole alignment (apart from PW-X) but the wiring can exit from different angles from the top of the motor and this can foul on the frame some times.
The PW-SE fits the same frame mounts as your motor and would make an excellent substitution, but we have not tried one in your particular model of Haibike, so you may have to trim the frame a little. It would work with your switch and battery though.
Failing that, the PW-TE is on an identical platform, but does have a lower power output. It would be interesting, if you could get your bike to us, we could try a bunch of motors and scenarios.
great info again mate. i am looking at getting a new bike in the new year and was hoping to keep this bike for a spare or for my eldest son ( once he grows a bit lol ) so this is at least a positive going forward.
Im located near Manchester so i dont think its just a quick trip to get the bike to you but i am open to maybe doing this to test the ideas in the near future.
Haibike Sduro Hardseven 2.5 size L
SDG Bel air saddle.
Spank spoon grips.
Trans X Ascend 170mm Dropper.
DMR Defy 35 stem.
Reverse Base 800 mm Riser bars.
Magura MT5 Brakes.
Rockshox 35 29er forks.
Octane one 27.5 wheel set - Magic Mary front 203mm rotor, Hans Dampf rear 180mm rotor.
Miche xfm 27.5 wheel set - Magic Mary front 203mm rotor, Big Betty rear 180mm rotor.
Both wheelsets include Tannus inserts front and rear ( 4 in total ) and good condition 9 speed cassettes on the rears.
FSA 160mm cranks - condition good with lots of paint wear though.
DMR v6 flat pedals.
Rare Sunrace M9 clutch derailleur.
Custom diy wide narrow chain rings at 34T and 38T.
RSP chain catcher.
x1r-10 500wh intube yamaha battery good condition.
yamaha pw-st motor - Condition Intermittent, unable to actually diagnose fault, 3739 miles odo.
Yamaha display type A - good condition.
Brand new speed sensor fitted. ( Nothing faulty with the old one it turns out so included as spare ).
Overall the bike is in good condition with quite a few chips and scratches as I've rode the bike hard at times, fell hard at times but surface cosmetics were not important to me so its definitely used
Worth selling ?
As whole package or broken down ?
just curious
SDG Bel air saddle.
Spank spoon grips.
DMR Defy 35 stem.
Magura MT5 Brakes.
DMR v6 flat pedals.
RSP chain catcher.
Worth selling ?
just curious
I’d keep everything as you probably won’t get half of what you’ve paid for them, and no doubt as your children get older and start riding with you all the spare parts will come in handy over time. You’re obviously handy with the tools so will be able to build another bike just from buying a frame etc
Good point
Battery, control display, sensor and charger alone might be worth enough for a cheapish frame to build on
Good point
Well one day you’ll probably get that motor fixed or the PCB replaced and then you can build the Haibike up again. Children don’t need emtb’s, you can just tow them up the steep climbs if their legs have had enough
I can’t remember if it was Tom Cardy or Sam Pilgrim that made a towing video, but they were testing a Haibike’s towing abilities and you’d be amazed at what they were shifting. Think they managed a Ford Transit on flat tarmac!
It wasn’t Tom Cardy or Sam Pilgrm, or a Haibike. It was Chris Smith on a Kenevo 😆
Blog life update stuff
Finally had my neurology specialist consultation regarding my latest slipped/bulging/deteriorating disc's etc.. MRI has confirmed relapse of disc issues from 5 years back along with further disc bulges and now arthritis in the spine .
My surgeon was extremely honest and helpful ( my last surgeon was completely shite as a consultant and a butcher on the table ).
I was very happy with our conversations and his explanations to my scans and future needs. We have decided NOT to re-operate or steroid inject for now and focus on committed physio and specialist exercises along with current medications to build a stronger core more for the future as "it's not looking great in there but your still young and if we can avoid the evasive treatments it will be best for long term" The advice/plan is physio, specialist pilates, Yoga, swimming and to remain on an increased dosage of current medications. I was asked at the end of our consultation if I had any questions/concerns lol..... Obviously I had already covered my concerns and questions throughout the consultations etc but I responded with " I'm extremely satisfied with the advice and agree with most of the going forward except YOGA !! I'm not doing it, I will replace YOGA with my bike, I'm ok cycling yes ? " He laughed and said "cycling is fine, anything for the core is ok but definitely NO weights...ok ?" My response was "Deal ".
I have a follow up consultation in 3 months to review my current pain levels etc as he has said we can opt for surgery at anytime because it's easy for him but I have to deal with the afterwards. I really wish I had this guy the first time round as I probably wouldn't be where I am now if so.
So.....It's in my hands to fix me and also in my hands to get the beast fixed lol, I have finally sent the Haibike Yamaha PW-ST motor sent off for service and repair at ebike motor centre and in the meanwhile I have had a few analog rides on the trusty Scott Aspect which have been ok on the back etc but NAH!! I need power im going to really focus on building my core up with the advisory exercises etc but need to get back on the eeb asap.
I haven't forgotten I'm due a new full suss either and that's definitely still on its way
I have a few other health concerns that I need to sort first and just not rushing into it right now as my focus is more on getting fit enough to enjoy my rides because at the moment I'm just riding roads and I can't live a roadie life I'd rather do YOGA lol.
I'm optimistic but also realistic so I can do what I need to do and what I do is enough.
Peace y'all and remember....
Enjoy the ride
Well good luck with your physio and getting the bike motor fixed
Pilates is good so I have been told but don’t think you will do that either 😜
Sounds really positive and now you've got something to aim for - getting out on yer bike, thanks for the update and hope you get the other issues sorted in good time. 😀👍
2 rides out now on the refurbished motor and no signs of motor cut out, need to do an extended range test but both rides around 8 miles each so all is good.
Just gotta sort my shit out now
Longest ride out in a long time for both the beast and myself Solid 15 miles putting us both through some heavy climbs and stress tests glad to report the motor survived without issues so can probably tick the cut outs off the issue list now. Here's some of the fun bits from today's ride.
Had a few good solid rides out now and the beast is back. Massive respect and thanks to @Bearing Man
The motor had a full overhaul and PCB replacement and is running like new wasn't expecting the odo to be reset but makes sense after a full service and replacements
I am in the process of getting a new bike but will most likely be keeping the beast as a spare, winter, future hand me down bike.
Been a blast lots of ups and downs and plenty of learning experience ready for my first full suspension.....
Thanks for the shout out, much appreciated :) Just for reference, the mileage is logged on the motors PCB. Unfortunately, when the PCB is changed, the mileage can't be transferred. But glad you're happy 👍
IMO.... A full overhaul and new PCB justified a reset odo The bike lives BUT !! The new addition to the garage will most definitely render the beast immobile for a while once again
Thank you for posting your journey.
I commute on the road on a 2019 Haibike FullSeven. And I have been working on my spine/back health for .. decades. Here is a couple of things I thought was worth looking into, perhaps you find them helpful.
  • Balance Core Training, Dr. Ryan Peebles, DPT He was a surfer with disabilitating backpain and found his way back to health and now helping other. His key idea is about training the inner core muscles to alliviate the root problem of backpain which is muscle imbalance.
  • Robin McKenzie, 7 Steps to a Pain-Free Life. This practical book describes what one can do to manage the back problem.
  • Brownstein, Arthur H. wrote Healng Back Pain Naturally: the mind-body program proven to work. Essentially saying you have to pay attention to your body.
Ultimately we, each one of us, have the power and are responsible for our health. Now use the power, make good choices.
One possible thing to do.. if you can, get rear suspension on your bike.
Take care,
Take care,
Thanks, good advice all round
Currently working on building my core and have upgraded to a full suspension too.
Paying homage to a Hardtail beast that gave me so much fun, I think out of of all my footage this does it justice nearly I need to get back out on the beast soon even if it's just for nostalgia but wow.. I had so much fun on the beast which I will never forget
As it turns out, the motor is not performing correctly and is under investigation lol
Massive respect to ebike motor centre for going above and beyond to try and get to the bottom of the issue
To be continued....
..... Continued So after some really shitty family issues over the last week we finally have some good news regarding the Beast...
Summary: My original motor developed a strange irregular intermittent cut out and after lots of testings and theories it was time to just get it sent out for a full overhaul and PCB replacement, The motor returned had solved the cut out issues but felt strange ( very low powered feeling post service ) at 1st I was thinking it was lack of fitness or the fact my new bike ( The crafty ) has much more power...But I did some well known test climbing rides and it became clear it was the motors power struggling and not mine.
After discussing with Pete we thought it could be a setting on the PCB board having not been set after service so I sent the motor back only for my motor to pass the testing.
My motor was returned and I set out to test it but the power seemed very low still and I provided a video showing the issue, Pete now going above and beyond now decided to send out a test motor and that motor has been fitted/tested and is performing as expected.
We have agreed on a solution which for me is outstanding service from eBike Motor Repairs & Servicing - Homepage and more so from @Bearing Man Pete.
Seriously big thanks and appreciation for all the efforts to resolve my issue
    677K
