Rail (625Wh) Considering a new Rail 7, Gen 2, Medium, Dark gray.
Gosh guys, my first ride was a hoot. Rode 5 miles on a trail that I know well. I just rode in 2-TOUR, never even tried E-Bike or Turbo. Noticed that riding in the rocks seems to work better just pedaling lightly. If pedal too hard, it applies more power than desired. Same going into a corner... don't want to pedal to early on the exit.
The upper body workout seems a bit more intense than with the acoustic bike, while the leg workout seemed a bit less. Was still able to get a good cardio workout.
Gonna try to alternate rides with the e-bike and acoustic.
Andrew
Andrew
Then go down from 2-Tour to 1-Eco and keep your pedalling cadence up, you'll soon get used to it.
Well @andrewgc how you getting on? Takes a bit to get comfortable yet so much fun the learning curve is entertaining. I'm 5'11" and bought a large. Wish I'd down sized to a med as it's a big bike with those 29" wheels. Find myself using the dropper a lot!
I'm 5'10" and had a Trek Fuel EX M/L which was just the right size for me.
Unsurprisingly I'm bang in between Rail 2022 (alloy) Medium and Large. But I have large 'wingspan' so went for a Large then messed around with the cockpit to make it fit right. My 5'7" wife has a 2022 alloy Medium Rail (which of course I maintain) and it's definitely too small for me.
Guys, sorry I have not logged in here in a while, but I am absolutely loving my Rail!!!
I greatly appreciate all of the tips here too!
I have one issue that I thought I would run by you experts, before I take it back to my Trek dealer (which by the way I have a great relationship with... several really cool guys there).
Anyway, my RockShox shock is leaking. I am sure I can fix it as I routinely rebuild dirt bike forks and shocks, however this bike is so new.
Is this common issue with this particular shock?
Thank y'all so much.
Andrew
Andrew
Definitely not Andrew - glad the bike is treating you well. Mines been a blast this fall as well. Trek warranty is usually pretty good from all my experience and what I'd heard. See if they'll give you a replacement or even offer an upgrade?
Andrew
Shock looks dirty that is all. Do you have 100+ hours on the bike yet? If so, SRAM says to get the shock serviced etc.
Just mullet it, best thing I did to mine.
100 hours. Gosh, no way I would run suspension components that low with out rebuilding.
My Rail is at the 7 hour mark.
THANKS!
Andrew
If the shock still has the same sag as when it was set up for you and compresses and returns
OK then it's fine, just dirty.
I downloaded the SRAM repair manual (pdf), ordered the rebuild kit, and already have the correct "PLUSH" oil.
I will service it myself.
Thanks guys,
Andrew
Thanks guys,
Andrew
While you're doing that you could fit a Megneg upgrade, got one on my wife's bike, really does make a big improvement to the performance of the shock. Was sceptical about the reviews but they're right. For example:
Sweet. Thanks man, I will check it out!
Andrew
    Join 43,195
