• Warning!!
    UK Pedelec Law
    Worldwide Laws
Shimano EP6 / EP801 with PearTune or SpeedBox
The eMax software can (on EP801 motors):
- set speed limit to 50km/h (or is it 60 ?)
- set power to max 600w
- adjust wheel size if needed.
- some other stuff.
I set it to:
- speed limit 32km/h.
- power max 400w.
- enable electric shifting.
- rear sprocket max ring size: 50
Yesterday I went on a 32km ride, and it completed and at the end i had 32% battery left.
Bike: Orbea Rise M20 2023, upgraded fork, wheels, steeringbar, pedals, battery to large.
- some other stuff.
I set it to:
- power max 400w.
So you are using the latest eMax mobile app?
What does a license cost?
No....using the Windows version is step 1.
License is 119 euro (100euro plus VAT)
This is currently not a DIY job.....maybe in a later version.
The german (very friendly and very helpfull) tech needs to be connected to your PC via AnyDesk (free and no installation needed) and do his magic.
It takes a couple of minutes, and he will communite on your pc in Notepad.
You can follow his steps.
When this is over, I'm using the mobile version in the trails (version 2.40 currently)
OK, so I need to get a PCE1 or PCE02 Shimano connect device?
Shimano warranty void if you derestrict.
Yes understood, any company that makes eMTB motor will void the warranty of their motor
If you de-restrict it. De-restricting to get another couple MPH/KPH shouldn't damage the motor, also Shimano specs the EP6/EP801 as a Class-3 (28Mph) motor in the USA.
So with the exact same battery, software and motor here in Australia they are restricted to 25kmh, so in America 32kmh an hour is the speed limit so the Australian models could handle it easily at 32kmh without drama?
I am guessing, but I am sure that the EP801/EP6 motors are all spec and tested to handle 28Mph/45Kmh, speed limit is handle thru the software of the motor.
Any pirate upgrades void the warranty. I got replacement EP8 motor for half price a year after end of warranty but I had to return first, so they could check it hadn't been hacked.
- some other stuff.
I set it to:
- power max 400w.
Wow, speed limit 32km/h, 32km ride and 32% left!!! Are you by chance 32 years old? :)
Hi, does it work with Ep801?
I have been using the PearTune module on my EP6 motor for about 200 miles now with no error msgs, once I get to 500 miles I will say it's works. With that said the EP8/EP6 are the same motor/firmware tune from what I have read, just cover material is different. EP801 has different firmware tune, so not sure if it will pickup the PearTune module.
I have been using the PearTune module on my EP6 motor for about 200 miles now with no error msgs, once I get to 500 miles I will say it's works. With that said the EP8/EP6 are the same motor/firmware tune from what I have read, just cover material is different. EP801 has different firmware tune, so not sure if it will pickup the PearTune mod ule.
What's the part number of the Pear Tune module you are using?
Using an external electronic hardware box (like SpeedBox, PearTune, MBIQ, BadAss, RedPad as well as Planet3 „mechanical tuning“, etc.) which will manipulate the signal from the speed sensor will definitely not work on the new generation drive units (DU-EP801/DU-EP6) and for sure will generate E295 and finally E299 errors sooner or later and finally will completely block the motor support!
In this case Shimano has to unlock the drive unit and this is a highly time and money consuming process.
Also you will never get rid of the E299 and so your bike most probably is already flagged for out of warranty for a lifetime, even if the drive unit was unlocked again by Shimano.
It is very easy to detect such manipulated speed sensor signals for the Shimano motor firmware via their new antitampering algorithms which are built in the motor firmware., see e.g. here.
So, don´t try to use such "dongles".
Also don´t get fooled by some manufacturers (like PearTune) of such "dongles" if they advertise and claim their product as "EP8 compatible", because the wording "EP8" mosty creates major misunderstandings => Unfortunately Shimano has branded the new DU-EP801 (released end of 2022) and the older DU-EP800 (released in 2020) on the right side motor cover with the “EP8” signature.
However, the older DU-EP800 and the newer DU-EP801 are completely different types of drive units in mechanical, electronical, firmware and software aspects.
To visually distinguish these two motor types, you can have a look at this German forum post or also this one.
The only way to speed up a DU-EP600 or DU-EP801 based bike in a long lasting and absolutely errorfree and hassle-free way is via a purely software based tuning!
Check eMax-Tuning for this and maybe also search for the solely positive ratings and feedback posts of eMax-Tuning (e.g. in this forum).
Yep that is a Shimano EP6/EP801 fact, if the motor detects any oddity in the rear wheel sensor and you will get the E295 error:/ I was using a PearTune for the EP6/Ep801 and had the E295 error a couple of times, so I when with the ePlus flash software and converted the EP6 into a class-3 28mph, no issues so far.
Thanks for your reply and information.
However, after PearTune (where you also have thougth "everything seems to be fine" according to this post and didn´t realize that it will throw E295 errors, which btw. you cannot clear...), in my eyes you again have backed on the wrong horse with EPlus, because the Italian guys from EPlus obviously felt pressurized by eMax-Tuning (because eMax-Tuning already does DU-EP600 and DU-EP801 optmizations flawlessly since more than 2 years).
So EPlus seems to have created a "quick and dirty" solution for US class 3 mode (with max. 45km/h) which they finally have released in April 2025, but can leave your drive unit in a problematic state in which you e.g. cannot reset this US class 3 state anymore (in case of a warranty issue or if you just want to go to a regular service appointment).
Also take in mind that (in comparison) to eMax-Tuning, the EPlus solution is "server based"!
So, if (for whatever reason) the EPlus server will be taken down (e.g. by Shimano due to legal enforcement), you then have no way to reset your bike to the initial state and so are left with a bike without any warranty.
With eMax-Tuning, you easily can do this reset by yourself in an offline mode and no connection to any internet server is needed for this.
Have you ever compared the quite poor ratings of the EPlus apps in Apple´s AppStore and Google´s PlayStore(see e.g. here and here) to the excellent ones from eMax-Tuning, see e.g. here and here? I think this tells a lot about the differences...
In my eyes EPlus is just trying to sell tuning products for anything and everything and is not focussing on important details and working with love on these things.
eMax-Tuning is doing software development solely for Shimano STePS systems since many years and is caring about customer service at its best.
BTW.: The eMax-Tuning solution also is cheaper than EPlus. :)
For sure everybody can decide by its own and I seriously hope that you will be happy and hassle-free with the solution you have chosen.
Just my 5 cents. ;)
However, after PearTune (where you also have thougth everything will be fine according to this post), in my eyes you again have backed on the wrong horse with EPlus, because the Italian guys from EPlus felt pressurized by eMax-Tuning (because they alread do DU-EP600 and DU-EP801 since more than 2 years) and created a "quick and dirty" solution which can leave your drive unit in problematic state in which you e.g. cannot reset this US class 3 state anymore (in case of a warranty issue or if you just want to go to a regular service appointment).
Also take in mind that (in comparison) to eMax-Tuning, the EPlus solution is "server based", so, if (for whatever reason) the EPlus server will be taken down (e.g. by Shimano due to legal enforcement), you then have no way to reset your bike to the initial state and so are left with a bike without any warranty. With eMax-Tuning, you easily can do this reset by yourself in an offline mode and no connection to any internet server is needed for this.
Also the eMax-Tuning solution is cheaper than EPlus. :)
Just my 5 cents.
Thxs for the info on the differences between eMax & ePlus software. My EP6 is out of warranty and I don't plan on rolling back to a class-1 eMTB. I have looked at the eMax website, but they don't have any information on their software works with a EP6/EP801 motor. I may download the eMax software and see how it works.
Thanks for your speedy reply.
See here in the "support" section of the eMax-Tuning - website where there are a lot of documents.
Especially in chapter 12 of the latest version of this document you will find all information related to the DU-EP600 and DU-EP801 drive units.
Also there is always up to date information in the "news" section. :)
BTW.: Even if you are officially out of warranty, Shimano sometimes may replace your drive unit free of charge on "goodwill" (at least if you will bring back the drive unit to a traceless initial state before sending it to Shimano).
However, this mostly depends on the mood of the employee who is dealing with the case. ;)
Emax software is easy and I have set both Ep6 and EP801 to US class 3 without problems.
