Searching for a M500 nylon gear
Galio
France
Hello,
My Nylong gear is faulty now.. then i bought an other (the only one available= the M600 nylon gear), from ali.... and it doesnt fit. Its a little different....
Can somebody help me?
Or maybe it will be better to upgrade the M500 to the M600 motor by buying only the stator and the rotor ?
Thanks Vikinol.
If anyone knows if its possible to upgrade this motor, otherwise i'll be obligated to purchase the gear set on this website.
Hmm, its without bearings. Do you know how to replace or buy the bearings and this small steel gear?
It's possible, all it takes is a little work and the right tools. I changed it but I can't test the motor as the battery broke during the break 😭
Looks nice (y)
Could you please write some tutorial how to do it?
I dont need this at now, but may be useful for some others in future.
Looks nice (y)
you need a tube of the same or similar diameter as the nylon gear
you need to place the gear on the tube and tap the axle (very hard) from above until it comes out.
To reassemble the procedure is the opposite, paying close attention to the key that must be inserted into the axle.
perfectness :D
    670K
