SCHWARZWILD Bafang M820 with LCE 930 frame
KaroKönig
Paint-job part 1:
First white…
then Fox-orange…
gold-green-blue effect 😎
@KaroKönig , considering that this hole is meant for the brake, where are you planning to route the rear brake than?
Also, did you check, if at full compression, hole at the end of the chainstay stays big enough, so the cable doesn't get pinched between the chainstay and seatstay?
Other than that, looks neat.
Of course, the brake line also fits through and for the clearance at the dropout I had to make a 3mm edge break and reinforced the cable with shrink tubing
I swapped out the headset that came with it for a Ritchey one.
In order to fix the battery and attach the dual battery discharger, I made an aluminum bracket…
I attached the connections for the range extender and the charger with a rubber stopper and pull them out of the frame when necessary, I couldn't think of anything better 🤷‍♂️
View attachment 124280View attachment 124281
If you’re using axs, you can use the exit hole of the derailleur line for the range extender but it’s a bit far
    670K
